3808ci No surround
Joshwhite
Joshwhite Posts: 18
edited October 2008 in Electronics
Hi i just got a 3808ci and i have a 7.1 setup, i have the amp selection set to 7.1 but i have no surround l/r sound, all others work. I have them hooked into surround A. Even the audigy says error no surround l/r. What am i missing. Again the speakers work and are wired correctly but no sound. thanks guys.:D
Post edited by Joshwhite on
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    Oh by the way, not to brag but i got this open box for 657., either i scored or thats whats wrong.
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2008
    Shoot a PM to member Grimster, he can probably advise since he owns the same AVR. Also to note theres a new firmware update on your AVR, he can also chime in on that one for you.
  • Grimster74
    Grimster74 Posts: 2,577
    edited October 2008
    Okay, the first thing I would do is look into the settings. I want to say someone else had the same problem and it was a setting issue. I'm sure you've already looked into it but if you go to manual setup/speaker setup/speaker config. check to make sure the side surrounds did not get turned off somehow. If by chance we all talking about the rear surround, also make sure that the amp assign is set to 7.1, the 3808 defaults to zone 2 if I'm not mistaken. If all that checks out okay, double check to make sure all speaker connections are tight and making good contact with the receiver. Let me know if this all checks out and then I'll look into it further. Oh yeah, if/when we get the unit up and running, Sherard is correct, the new Denon feature pack is kick ****, well worth the $100 upgrade.
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    thanks grimster love the unit so far, updated from an htr 5760 so WOW on the difference. ill check the settings again, i did an update last night so im all good there, do you think id get the rebate from denon since it isnt new? I did get it from BB thanks again ill let you know the results soon.
  • broncsrule21@
    broncsrule21@ Posts: 113
    edited October 2008
    Most likely the amp assign setting. (like said above) Your choices are 7.1, 5.1+stereo, 5.1+ bi-amp, and one other I can't remember.
    HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
    Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
  • Grimster74
    edited October 2008
    If you purchased the unit recently from BB, I would think you could possibly get the feature pack for free, worth a shot anyways.
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    ok guys the amp selection is set to 7.1, i have the speakers hooked up to surround A, the speakers work fine i hooked them up to FR channel so i know there is no conection problem. Still nothing is there anything else? what if i try to reset the unit, if so does it require all updates again? maybe i should just call denon monday, cant they diagnose it over the network? thanks again guys id hate to take it back, i really like it minus the current prob.
  • Grimster74
    edited October 2008
    Okay, if you do a microprocessor reset, you will NOT lose your firmware updates. The only thing you will lose is all your settings, speaker info, radio stations, etc. and of course all Audyssey settings. If you reset the unit and it still doesn't work, your best bet would be to contact Denon Tech support.
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    Cool ill give it a try im not worried about the audyssey settings since i cant complete the auto cal. it says no surround l/r. Even when i go into speaker level adjust it shows all the speakers there for adjustment, just no sound from the sur. l/r, i havent tried to hook them up to sur. b yet but i dont know if that would make a difference, thanks again.
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    ok sur b works fine but if i do audessey it checks sur a and since there arent any it doesnt bother checking surb makes sence. so im doin a reset now.
  • Joshwhite
    Joshwhite Posts: 18
    edited October 2008
    Yea... it works, after i tried to set it to sur. b i just tried sur. a just to make sure before i reset the avr. To my surprise it worked fine... i wonder if for some reason hooking it to the sur. b, it unfroze, for lack of a better word, sur. a. Well i did the audessey and man what a difference, thanks for all your help chat with you soon.
  • Grimster74
    edited October 2008
    Cool, glad to see it worked itself out. Enjoy your new toy and if you have any other questions about the unit, please feel free to ask or PM me. By the way, welcome to the forum.
    Rob
