(pics) Where can I put this sub?
DannyD
DannyD Posts: 133
edited October 2008 in Speakers
As you can see from the picks I have my subs stacked because of room constraints. I'm wondering what everyone thinks if I take one and put it beside the component rack facing perpendicular to the one beside the doors. Having the sound waves crossing eachother...is that a bad thing? My other option is to put one in the back of the room but it would have to be right in the middle of the back wall because I have bookshelves on either sides. Any thoughts? By the way...my cats eyes are really red:rolleyes:
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2008
    I think you have bigger problems than sub placement............you've got "Devilcat" in your living room.:D
    I like them stacked as they are for HT, and separated, between your 10s and TV with the electronics moved to make room for 2 channel sound. This allow your mains to be spread out somewhat.
    You could also lose whatever your TV is on and find a way to put them under your TV, isolated from direct contact of course.
    The back of the room, or firing toward each other would both be my last choices.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2008
    Thr cat keeps looking me.
  • curved
    curved Posts: 664
    edited October 2008
    I would keep it where it is.....maybe toe those 10's in a hair.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • maximillian
    maximillian Posts: 2,149
    edited October 2008
    From what I have read on this forum.... some people prefer stacked subs because it seems to give a deeper sound, some people prefer stereo subs for music listening, and some people prefer a sub in the front and one in the back. Really, you should try them out.
    I also second Dennis' comment that you need to separate the fronts more.
  • Eric W
    Eric W Posts: 556
    edited October 2008
    What is that "as the crow flies" cable in the back of the rack? :D
    -Eric
    -Polk Audio
  • rtart
    rtart Posts: 852
    edited October 2008
    DannyD wrote: »
    If you are interested in optimizing the placement of your sub without a sophisticated sound metering device, it takes a method that seems a little unorthodox. Some call it "crawling for bass". Here's what you do: place your sub in your normal LISTENING position. That's right, put it right where your chair normally sits. Stack them if that is your configuration. Play a bass test tone, or music with lots of strong bass. Crawl around on the floor near where you think you may want to put your subs. Try corners, and places about one-third of the room width from the side walls. Listen for the strongest bass in an area. Where your head is will be the best place for your sub to finally reside.
    If you have an AVR with an auto-cal feature, use it first with the sub in your listening position, then try the crawling routine.
    Looks stupid, but works great! It is a good idea to do it when the house is empty, however :)
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    If you need something to set your drinks on for the movie - put one on each side of your seating postion. (get a piece of glass cut for the top so you don't leave marks in the wood though)
    They will be nice and close that way and you can still get good effects without blowing out the rest of the house (it may even lessen the room interaction).....
    Michael
  • ward91
    ward91 Posts: 338
    edited October 2008
    When you have two identical subs/speakers next to/on top of each other they in effect become twice as loud?? (+3db) pro audio systems make the most of this by placing many subs together in one array. that way you need less power to make more noise.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    ward91 wrote: »
    Actually stacking adds +6db. If they are separated (to help with room nulls) they add +3db.
    +10db is twice as loud (and takes 10 times the power). +3db is slightly louder and takes twice as much power.
    You stack subs not just so you can play louder, but on loud passages the subs play with lower distortion as the amps and speakers are not pushed nearly as hard. Setup is also much easier as you only have two variables to play with (sub location and you listening position).
    You separate subs and lose some of the gains you make with stacking, but you also minimize the effect of the room on bass being played. It can help with problems of boomy bass or big peaks and nulls. You also may end up with a much wider sweet spot for bass rather than just your main listening position. The tradeoff is not as much gain (as I already stated) and it can be a real pain in the **** to get set up correctly. (to acually make the sound better rather than worse) Once you do though - it is well worth the effort in my opinion.
    Michael
  • Eric W
    Eric W Posts: 556
    edited October 2008
    McLoki wrote: »
    Michael
    Well said! :)
    For everyone else, I'll explain why you get 6 dB when stacked- you get 3 dB from the doubling of the available amplifier power and then another 3 dB from the "mutual coupling" of the cones in such close proximity. If seperated, you no longer have the mutual coupling, but as McLoki said you have a better chance of smoothing out room nulls and nodes.
    In professional PA systems, the spaces they're being used in is quite large, either outdoors, a theater or arena where small room acoustics (like the house) are different. And the "sweet spot" is considerably larger. Here, if the subs are seperated it generates a "power alley" in the area between the sub stacks and uneven response throughout the audience. So subs are almost always center clustered, either on the ground or flown. More complex PA systems will actually delay the outer boxes of their subs in order to "shape" the distribution of the bass for more even audience coverage.
    For home audio, it depends on the goals of the system. Generally, maximum SPL = stack. Largest coverage with smoothest response = stagger. In the end, experimentation is key and do what sounds best for your system.
    -Eric
    -Polk Audio
