RTi38's seem somewhat lacking...
hertzlbl
hertzlbl Posts: 5
edited June 2003 in Speakers
I am currently in the process of building a home theater. My existing "stereo" speakers are Polk Monitor 10B's, which I have thoroughly loved for the past 16 years. In preparation for my home theater, I purchased the following additional components:
FXi30 - Surrounds
PSW404 - Subwoofer
CSi40 - Center Channel
Yamaha RX-V1300 amp (100 watt/channel)
I've been using this setup for the past couple of months with no complaints other than a slight difference in timbre between the Monitor's and the rest of the system.
I am now preparing to setup my hometheater in the basement, so I need an additional pair of main speakers. (I am planning on keeping the Monitor 10B's upstairs in the living room for music listening only. I prefer to keep the new front speakers small, or at least narrow, so I can maximize the wall space for my theater screen.) Based on the "Build a System" feature on the Polk Web site, I purchased a pair of RTi38's to match my existing home theater components (excluding the Monitor 10B's of course). When I set up the speakers this evening to play some "challenging" music, I must say I was somewhat disappointed. (I always play Yes's "Yours is no Disgrace" whenever I am evaluating and comparing musical components. Been using the same song for 17 years!) The midrange/bass was sluggish and lacked punch. It actually seemed to warble a little bit at one point. I then came to the realization that the pair of RTi38's cost about one half the price that I paid for the Monitor 10B's 16 years ago! What did I expect?
Basically I would like to upgrade the RTi38's (i.e. return them to Circuit City), but I'm concerned that if I go with the LSi series, the 4 ohm difference in impedence (8 ohm vs. 4 ohm) will adversely effect the dynamics of the 5.1 system when watching movies. I really can't justify starting over with all new surrround sound components (Center, rears, and sub). Any suggestions out there?
Ben
Post edited by hertzlbl on
    VR3 Posts: 29,550
    edited May 2003
    The RT35i is a speaker, a real mind boggler. However as I have found, seperates are the only way to make Polk sing. Im not exactly sure what Yamaha you have, but my Old yamaha was pretty muddy, and I agree the RTi38 woofer is kinda behind, but I love the new tweet. I suggest walk into seperates and dont look back. The RTi70, or RTi150 will match the rest of your system. Adcom, AMC, Rotel, NAD are all seperates that are really good, Rotel is pretty expensive. NAD, AMC, and Adcom are good on da cheap! Well good luck with your system!
  • jkratzer
    jkratzer Posts: 148
    edited May 2003
    If you are not happy with the RTi38's you could exchange them for RTi70 towers if you can acommodate towers. They would match just a well with your center channel and surrounds. I love my RTi38's though but I'm using a Denon 3803 receiver which matches well with the RTi series.
    You are right about the 4 ohm LSi's which usually require separates. Unless your receiver is specifically rated for 4 ohm loads, you are better off staying with the RTi line. I've also heard that the LSiC center channel is kind of thin sounding for home theater.
    Keep us posted on what you end up doing.
    My 7.1 setup consists of:
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RTi28s side surround
    FXi30s back surround
    PSW202 Subwoofer - Hey, it's my first sub!
    RCA 46" 4:3 RPTV
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2003
    I run RTi38's no problems, after some mount/location tweaking that is, with a Sony ES receiver. The location or mounting area of the RTi38 will influence the sound greatly. They are a very nice speaker, but have to be set-up correctly. They are bookshelves, so to scompare them to M10b's is just not fair. I've owned both also.
    The LSi is the hard-on favorite, but your Yamaha won't be able to run them efficiently. You need some hardcore, clean, high headroom power for the LSi, and most HT's don't include that, because there isn't a huge need to do so.
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2003
    No offense but you heard wrong, I had a cs400 before upgrading to the Lsi series, a great speaker to be sure but the LsiC is even better (INMHO).
  • fireshoes
    fireshoes Posts: 3,167
    edited May 2003
    I also strongly agree about the LSiC being very good. I wasn't expecting as big of a difference as it was. I did tweak the positioning of mine a bit, angling it down to get more of a direct shot at ear level. I am completely satisfied with it. When I had my RM7600 I always felt the center channel was reproducing everything it should, but no such feelings with the LSiC.
  • jkratzer
    jkratzer Posts: 148
    edited May 2003
    Sorry Fireshoes and Frank Z. Thanks for keeping me straight on that LSiC. :)
    It is good to know that the LSiC is a step up over the CSi40/CS400i center for home theater so that I have a future upgrade path.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • hertzlbl
    hertzlbl Posts: 5
    edited May 2003
    Vr3MxStyler2k3 and jkratzer ,
    Thanks for your advice. I went back to Circuit City and traded the RSi38's for the RT70's. I absolutely love the RT70's. The Midrange and tweeter sounds every bit as good as the Monitor 10B's! Now I'm ready to Rock in Surround sound!
    VR3 Posts: 29,550
    edited May 2003
    congrats, rock on and enjoy da speakers!
  • jkratzer
    jkratzer Posts: 148
    edited May 2003
    You lucky son-of-a-gun! I'd do the same if it wasn't for the "wife factor". :)
    Enjoy.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • jkratzer
    jkratzer Posts: 148
    edited June 2003
    Went to CC...
    Saw RTi70's on sale...
    Listened to RTi38's...
    Listened to RTi70's...
    Liked RTi70's better...
    Forced wife to listen also...
    Wife liked what she heard...
    Bought RTi70's...
    Traded RTi38's...
    Hooked up RTi70's...
    Home theater nirvana arrived!
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • dorokusai
    edited June 2003
    Congrats on the new towers!
    Of course you have more bass, its a tower silly! :D
  • GuitarheadCA
    GuitarheadCA Posts: 400
    edited June 2003
    The 70's are such a great speaker. I love mine- congrats on your new purchase:D
  • Tour2ma
    Tour2ma Posts: 10,177
    edited June 2003
    jk,
    So much for the "wife factor", huh? :lol:
    More later,
    Tour...
    Vox Copuli
  • faster100
    faster100 Posts: 6,124
    edited June 2003
    I'm glad i don't have a wife factor :D I have a wife but she loves the audio thing and she helps pick speakers and stuff.. she says she will never tell me no about stuff i'm into ie: audio, my coke collection and such, Until it cost thousands then we have to dicuss it. Like the jet boats we just got interested in after a boat tour over the weekend :cool:
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • dorokusai
    edited June 2003
    My wife supports me also, but for some strange reason, not the Russian wife thing.....I don't know what was wrong with her that day....
  • jkratzer
    jkratzer Posts: 148
    edited June 2003
    Those of us with supportive wives are lucky.
    She was more supportive than I would have thought. Although she preferred the smaller size of the bookshelves, all it took was a short listening session and then she said "When do we upgrade?". With the RTi70's on sale for $100 off per pair, plus wife support, I knew those speakers had to be mine. :)
    In the past month I've upgraded my CSi30 to the CSi40 and now RTi38's to RTi70's. CC gave me my full purchase price and ate the depreciation. I'm just wondering what CC does with the used speakers.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • weavercr
    weavercr Posts: 289
    edited June 2003
  • jkratzer
    jkratzer Posts: 148
    edited June 2003
    Originally posted by weavercr
    OPEN BOX sale
    That explains it. Thanks.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • jkratzer
    jkratzer Posts: 148
    edited June 2003
    faster100,
    Tell us more about this "coke" collection. ;) LOL. BTW, your wife sounds cool.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • faster100
    edited June 2003
    Well i have collected coca cola items for 10 years now, Some old and some new, Recently we almost decided to sell it all.. even posted some stuff on the board, Then i came to my senses and decided to keep it.. I sold a few small items before i realised you can't give up a 10 year collection because you don't have enough room in the house, you put some away and wait to ya buy a larger house, that's next in a few years..kids and play rooms take first for now.. I still have a Coke room, but it just has kids toys in it also :) .......
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • TonyPTX
    TonyPTX Posts: 545
    edited June 2003
    Yeah, it's the nice thing about CC. Too bad they don't carry LSi's as I'd be all over 'em. I bought a pair of Polk RM6700's in December w/a PSW404 and just wasn't happy with 'em. I brought them back (the 6700's) and picked up a pair of 70's and a CSi40. Man, those combined with a pair of RT35i's for the rear and I have a great HT system. Matter of fact, I had to upgrade my reciever after since it was sub par to the speakers. I'm running with the Rotel crowd now.
    Congrats on the new purchase. Sorry I missed this thread. I would have recommended the 70's as well.
    Damn....8 lines...I've gotta put my sig on a diet now....
  • faster100
    edited June 2003
    I love my rti70's.. Even more now i have changed from black to cherry.. look sweet and changed to monster 14-4 bi-wire from old crap i had.. I plan to keep these for some time.. rears will be the rti38s, and compliments of the new child tax credit if it comes through with the $400 a kid check they promise, i will also be getting the SV pb1 subwoofer in a few months.. :):)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    Hey Ben,
    In my opinion your not comparing your apples with similar apples. I have always said that I love the RT series for HT but find them in HT setup/playing CD's to be lacking. But no matter what the ad says, the Rt was born to play DVD audio. I think if you could put the 38's in a Surround situation in DVD audio..you might see them in a new light.....
    Like some have said in their posts as well, I have found that every tweek you do, cable, positioning, toeing all those things change the charachteristics of the Rt line noticeably.
    My 2 Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
  • jkratzer
    jkratzer Posts: 148
    edited June 2003
    Just noticed that Crutchfield just lowered their price for RTi70's again to $599.98/pair. That is a great price for fantastic towers so you hold-outs need to jump on this deal.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
