A-Bus System for the Home
Tollaksen
I just bought a A-bus hub for the house. It seems pretty staight forward but I was wondering if any of you guys have used or installed one of these in your home.
What am I getting into?
How is the sound?
What kind of speaker should I use?
Buy premade cat 5 or make my own?
Any other things to consider?
http://www.harmankardon.com/product_detail.aspx?prod=ABH%204
Have music throughout.
No room in the house needs to be without music with the ABH 4 around. The ABH 4 from Harman Kardon allows you to power up to four rooms off of this one A-BUS expansion hub. For systems without an A-BUS ready jack, the ABH 4’s onboard audio inputs add the simplicity of A-BUS technology to most stereo receivers.
Provides simple connection to any A-Bus ready Harman Kardon receiver
Easy interface adds A-BUS capability for multiroom systems
Power up to 4 rooms off of this one A-BUS expansion hub
Designed for easy mounting on wire backboards, or for shelf placement
Onboard audio inputs add the simplicity of A-BUS technology to most stereo receivers
Reciver Pre/Pro - H/K AVR-347
Amplifier - Adcom-7400 5 Channel
Speakers - SRT's
Projector - Sony Avl-aw15
Speakers - SRT's
Post edited by Tollaksen on
With abus you are limited to an amplifier in a keypad. So I guess it depnds on whether you like to play your music loud or if its just for background.
