Can I put a set of Peerless tweets in my 10B's?
Conradicles
Conradicles Posts: 6,339
edited October 2008 in Vintage Speakers
I wanted to replace my Monitor 10B tweeters which are the SL-2000 with a set of Peerless tweeters with the hole in the middle. Will that be O.K.? Is the crossover frequency correct? Thanks to all who will help in advance.:)
Post edited by Conradicles on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited October 2008
    Welcome to the forum
    I have used the Peerless in my SDA 2a's with great results and I did'nt have to modify the opening at all. The x-over frequency is probably not a perfect match but probably not far off either. You should check out the schematic post here and see where the caps and resistors differ.
    If you have to modify the opening at all I do not think that would be wise. You may be best served by purchasing a pair of RDO-194's from Polk for about $104. which is a direct replacement/upgrade from the 2000's.
    If the Peerless fit easily I'd give it a try and also order a pair of RDO's. Once you get the RDO's you can do a compairson and share your thoughts with us. You can always re-sell the RDO's here if for some odd reason you don't like them.
    By the way where are you from?
    Drew
  • Conradicles
    edited October 2008
    Thanks. I have the Peerless in my 10A, just wanted to make sure it is O.K. for the 10B. I will eventually buy the replacements from Polk when I get the extra cash.
  • Conradicles
    edited October 2008
    You were correct, it would take a modification. They did not fit. Could mod them, but think I will take your advice and get the new ones from Polk. Thanks a bunch.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2008
    You should be much happier with the new ones from Polk. The SL1000 and Peerless can be swapped but neither is a drop in for the later SL2000 or RD-0194.
  • Conradicles
    edited October 2008
    Thanks for the info. Do you like the SL-1000?
  • dorokusai
    edited October 2008
    Absolutely not. If at all possible I'd swap in a Peerless.
  • gdb
    gdb Posts: 6,012
    edited October 2008
    Hi, how much difference is there in the recess, that wont allow the peerless to fit ? perimeter or depth or both ? If you know someone that's good with a router it shouldn't take too much to modify the openings. If you need it, I could send you a peerless faceplate that you can use as a template to mark out the new perimeter, after that, if you're careful a utility knife and a sharp chisel would do the trick ! Good luck whichever way you go !:)Geoff
    If you want to sell the Peerless, I'd be interested in them.
  • dorokusai
    edited October 2008
    The recess is bigger, not smaller.
  • george daniel
    george daniel Posts: 12,096
    edited October 2008
    dorokusai wrote: »
    oops,, edited
  • gdb
    gdb Posts: 6,012
    edited October 2008
    OH OK, got it ! Nevermind. :o Geoff
  • dorokusai
    edited October 2008
    A couple ppl have used the router idea to modify the older ones so it's an honest suggestion GBD.
  • gdb
    gdb Posts: 6,012
    edited October 2008
    Doro, is it a bad thing sound wise if the tweeter doesn't extend to the edge of the larger recess, or is it a matter of appearance? Would a carefully applied fill of black silicone work OK ?:confused:Geoff
  • dorokusai
    edited October 2008
    gdb wrote: »
    I would make a wood template for the hole and mount the tweeter on the template. Use some gasket tape for it and that should let you play around. I don't think caulking the opening is a good idea.
