Best way to connect 2 runs of 12awg speaker wire?
Veccster
I am running 80 feet of 12awg speaker wire to connect an outdoor speaker. The wire is running through my attic and will not very accessible once laid. I have 2 lengths of wire that I plan to use - 50ft and 30ft. What is the best way to connect them together?
It doesn't have to be the BEST way out there...it's still an outdoor speaker
I just don't want it coming loose over time and deteriorating the sound. The wire is terminated at the other ends using banana plugs.
Post edited by Veccster on
Cut your wires so one leg is longer than the other(on each cable), and solder them together. Wrap the whole thing with electrical tape. This way no matter what there is no chance of a short because the joints are not over lapping.
Ben -
solderTNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Add one more vote for solder. Looks like the solders have it.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Does it matter the kind of solder I use? I believe I have lead solder wire at home.
To do this, I will just wrap one wire around the other (like a candy cane) and drip the solder on it to seal it. I'll wrap everything up in electrical tape as well. -
Solder, like everyone else said, but before you put on electrical tape, use heat shrink wrap. You can get it from radioshack and it'll seal better than electrical tape. If you don't have a heat gun you can still get it to shrink by holding it very close to your soldering iron (but not touching). THEN wrap the whole thing in electrical tape.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I have a heat gun and will pick up some shrink wrap as well.
Thanks again! -
12 AWG is a pain to solder cause of the amount of metal. You need a fairly beefy soldering iron.
Also- hairdryers work well for shrinking heatshrink
-Eric
-Polk Audio -
I agree, very hard to solder correctly. With wire that heavy, I usually use a crimp connection, you will need a set of real crimpers to do this well, then solder each side. Cover with heatshrink tubing, no need for electrical tape on top of that.
Use a twist on wire connector like you would to wire an outlet.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
solder and heat shrink is best. If you don't have soldering equiment use a crimp style butt end splice then heat shrink. Different spaced lengths for +/- as Ben said is best. Any sun exposure?[
I was wondering if the thickness would make it more difficult to solder. My iron is pretty old but I'm going to give it a go. The total length is 80ft so I needed to use a thick wire like 12g.
The wire will be run behind my house siding and will have no sun exposure. Once hidden, the wire will not be disturbed and the connection should remain tight.
Thanks again for the assistance.
