Large means what? Soundbar / Onkyo Speaker setup problems
turn55
I need some terminology help. My Onkyo 605 AVR Speaker configuration screen does not use Large and Small terminology, but rather allows me to select frequency crossover settings in Hz. So does Large mean high Hz, or low Hz??? I am supposed to select one of the following settings for front,center,surround,surround back,LPF OF LFE:
Full Band
40 Hz
50Hz
60 Hz
80 Hz
100 Hz
120 Hz
150 Hz
200 Hz
Could use some help.
Full Band
40 Hz
50Hz
60 Hz
80 Hz
100 Hz
120 Hz
150 Hz
200 Hz
Post edited by turn55 on
I usually set my speakers crossover btw 80-100. I let me sub catch everything below that. I am no expert but i was always taught to have your sub crossover set to where your speaker crossover stop. Typically you dont want too much bass coming out of your speakers. I have an onkyo 6.1(see my system rdb2001, in my bedroom), I cross them over at 100 and they sound great. Hope that helps
large would be 40Hz and small would be 200Hz at least in mine it's that way.. i'm sure 40Hz would be similar in all receivers crossovers.PolkFest 2012, who's going>?
From the Polk instructions, they want you to set the surround bar to LARGE. I'm guessing the surround bar has it's own built in crossover. If that's the case I'd set the receiver to FULL BAND, to be on the safe side select 80 or 100. LARGE usually denotes that their is no crossover settings, playing the full range spectrum. Many receivers like yours, you can select a crossover point.
