Best 2 driver tower? (A tweeter and a mid/bass driver?
c_corie
c_corie Posts: 138
edited September 2008 in 2 Channel Audio
Wondering if anyone makes a nice simple, inexpensive good sounding tower-good looking? as well, with only 2 drivers? Just kind of wondering, cause you seem to only see this design on really cheap stuff, or crazy expensive stuff, is there a "midprice market" for this sort of tower?
Post edited by c_corie on
  • curved
    curved Posts: 664
    Looks is going to be subjective......RTiA5????
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • c_corie
    c_corie Posts: 138
    I meant more so 2 actual drives not just 2 way. Like just one 5 1/4-6 1/2 inch woofer and a tweeter. I know KEF has one, but you only get it in the UK i think.
  • Face
    Face Posts: 14,340
    What's inexpensive?
    KEF is available stateside. They aren't exactly cheap. And if you like a forward presentation, you'll like them.
    Another good two way/2 driver speaker is Tannoy, but again, not exactly cheap.
  • c_corie
    c_corie Posts: 138
    yea the only thing i had know of until now was the av123 tower, the x-sls encore Mid-Tower Loudspeaker. Inexpensive is anything under $700 per pair (if its good quality), cheap would be like under $400 pair and sounding good. Also im in CT and the only thing around here is CC, Best Buy, and B&W and really expensive dealers, no mid-fi stores
  • steveinaz
    steveinaz Posts: 19,546
    Look at EPOS offerings...
  • dkg999
    dkg999 Posts: 5,647
    steveinaz wrote: »
    +1 on that
    DKG999
  • c_corie
    c_corie Posts: 138
    I checked out the Epos site and all their floorstanders have 2 mid/bass drivers and a tweeter. Maybe just one driver and a tweeter blows then? I can't say I've actually heard that combo that wasn't a bookshelf speaker. Maybe it'd be easier and cheaper to build one?
    Also do single driver + tweeter floorstanding speaker sound any different then dual driver + tweeter towers (I've heard many of those.) If they're both 2 way systems?
  • steveinaz
    In my experience, usually (but not always) dual woofer type setups have less distortion because the load is being split between 2 drivers, requiring less excursion from both. Now, that's not to say they are necessarily better....that varies speaker-to-speaker and is largely a subjective decision from the listener.
    Long story short--go listen to speakers and decide for yourself.
  • lakesailor
    lakesailor Posts: 319
    I am a big fan of what the ‘Brits often refer to as “compact columns” and certainly there is much to be said for the single driver/single tweeter approach. I do find there is an audible difference; and in fact very much enjoy the very speaker you are currently looking for.
    The downside is that good ones are hard to find that are relatively inexpensive. You might try the Mordaunt-Short 904i or for more money both the Monitor Audio RS5 and Totem Arro’s are very nice. Good WAF on all three as well.
  • gidrah
    gidrah Posts: 3,049
    I've seen some nice vintage Altecs go for that much. Consider them a tower with a wider base.
    Make it Funky! :)
