Adhesive for cell phone electronics contacts?
Ricardo
Ricardo Posts: 10,636
edited September 2008 in The Clubhouse
I am changing the LCD screen to a Motorola Razr phone; the screen body has a couple flexible PCB's held in place by some kind of adhesive. Anyone knows what adhesive is this and where can I find it?
Thanks!!
SOPA
Post edited by Ricardo on
  • tugboat
    tugboat Posts: 393
    Ricardo wrote: »
    Thanks!!
    It's just the standard double sided tape that can be found at any hardware store (it's very thin and white). They usually sell them in a sheet of small squares that can be trimmed to size. The last sheet I purchased was about 1.49. Just make sure you don't get the heavy duty stick or it will probably break the PCB if you try to pull it apart.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  • Ricardo
    Hmmm. As simple as that? I'll give it a try. Thanks!!
    SOPA
  • Jstas
    Jstas Posts: 14,981
    I have yet to find anything thinner than 1/16th in a hardware store. I had to get 1/32nd thick stuff directly from 3M.
    Expert Moron Extraordinaire
  • tugboat
    tugboat Posts: 393
    Jstas wrote: »
    The HW store down the street from me has them 1/32 to 1/8 and from barely sticky to incredibly sticky. It's an older HW store, so they have lots of stuff not found in the chain stores.
