Well I'm all moved in...
cfrizz
And my system is back up BUT my RTA's may not have survived the move totally intact.:(
At first listen they sounded fine, but now when I played them this morning I noticed that background vocals were missing, and the music just sounds off.
I will go home tonight & check all the connections, but after that I'm stuck.
I'm not about to start buying replacement parts for 18 yr old speakers that I can't figure out what is truly wrong & have no way of repairing.
Damn this rots big time!
Post edited by cfrizz on
Cathy sorry to hear about your beloved RTA's... maybe a wire came lose or something like that. try rehooking them up to your amp again. maybe you got a wire mixed up or something.
and yeah congrats on the new place.
PolkFest 2012, who's going>?
Congrats Cathy. We must have pics! Hope you get our speakers on track.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Great opportunity to upgrade
Believe it or not...it could be caused by placement in the room and/or the dynamics of the room itself. It may be totally different from your previous place and moving them may (or may not) help. I have been suprised on a couple of occasions how just a foot or less can change the soundstage and imaging. Worth a try maybe.
If not, there are always GREAT deals on some new (used) stuff around here and I'm willing to bet someone will help you out. Good luck."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
BTW...congrats on the new home!"Just because youre offended doesnt mean youre right." - Ricky Gervais
Don't get too upset. If you can turn a screwdriver you can fix them. Most likely one of the mids froze. Push gently on the woofer, and see if any are stuck.
Ben -
Make sure you have the speaker cables hooked up correct, and they are not out-of-phase. It's easy to do, and on some speakers you can quickly hear the difference.
If that doesn't work, then trot on down to SpearitSound and get your listen on, or buy LSI's as you have the proper wpc for them
DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Maybe the background vocals liked the other house better?
I'm playin' I'm playin'...seriously I think Shack-daddy nailed it. You've been so used to the acoustics in your other place, you may have to mess around with placement a bit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Congrats on the move and sorry about the speakers.
engtazengtaz
Congrats on the move Cathy. Hopefully its nothing major with the speakers.
Enjoy your new home Cat, I pray the Lord blesses you and your new place.
Now then, in order for your speakers to perform properly you need to use an amplifier with at least 200 wpc.
sorry.
RT1 -
Enjoy your new place. Speakers and cats DON'T
travel well. Why is it movers don't break glassware,
but always nail the speakers?
Take it one step at a time. Hopefully it's something simple."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Gently push in on each woofer, make sure not are seized or making a scratching noise.
Replacement only requires a philips head screwdriver."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It turned out to be a loose connection! So much for double checking all the connections!:rolleyes: I did a quick by ear recalibration. I'll do a proper one this weekend.
I'll try to get some more pics up sometime fellas. I'm exhausted, between the move & learning a new job (after being told I was going to be laid off in Oct) I can barely see straight.
But at least I got my tunes back!:D Well mostly, I still need to get screws put into the studs on the back wall so that I can hang my back speakers. I don't know when I'll get that done!
You guys are GREAT thanks for the well wishes & help!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I wish I were closer. I know how it is to move. I hope you have help.
Ben -
Congrats on the move and getting the tunes back! I've always felt that once I get the tunes hooked up, the rest of the unpacking just falls into place...
Congrats on your new place, even better you found your trouble with the speakers.
Ted,
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Congrats on your new house. Also glad the speaker issue was resolved without being costly.
And to think I was just going to fly down there and save the day like a caped crusader with an SDA under each arm
Glad you got em fixed Cathy
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Congrats on you new home Cathy! I hope that you have good luck and health in the years to come.
I'm glad your speakers are okay. Time to kick back for a bit and enjoy home ownership!Carl -
Congrats on your new home.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
What the hell is the world coming to when Cathy says screw and stud in the same sentence............hahaha.........I still need to get screws put into the studs on the back wall so that I can hang my back speakers. I don't know when I'll get that done!comment comment comment comment. bitchy. -
Congrats, that place should be mostly soundproof, excepting the door to the hallway. Turn it up!-Ignorance is strength -
It's a great feeling I'm sure. Glad the problem was minor. Congrats Cathy.If there ain't no gold at the end of the rainbow, I'll settle for the pot.
Yamaha RX-A2020
2-Sony DVP-CX995V 400 Disc players
Sony BDP-S580 Blu-Ray Player
Mains:Polk RT2000P
Center: Polk CS400
Rears: Polk FXi A6
Subs:2-Polk PSW450 -
That's friggen hilarious -
DAMNIT Brett, I almost choked on my lunch! DON'T DO THAT!!!:D:D:D:D:D:D:D WAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!:D:D:D:DWhat the hell is the world coming to when Cathy says screw and stud in the same sentence............hahaha.........Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Time for those Dynaudios you listened to a while back.
LOL! You know that is exactly what I was thinking!:D BUT, my RTA's are just fine so I don't need to go shopping.
Which is a good thing since I'm going to have to shell out over $1000.00 to buy Title insurance!:eek:BaggedLancer wrote: »Time for those Dynaudios you listened to a while back.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
