Is there a better way to wire my whole system
SoundTrip
Like the Title says, I need help to make my videos appear better on screen and sound and music play better. PLS.,PLs.,Please.....
Here are my units:
Television: Samsung HL-S6187W
Panamax 4300EX
Receiver: Denon AVR 3805
DVD Player: DenonDVD 1920
Main (Front) Speakers: Definitive Technology BP-8
Center Channel: Bowers & Wilkins
Rear Speakers: Polk Audio RT 8
Surround Speakers: Definitive Technology BPX 1.2
Subwooofer: Miller & Kriesel VX 760
I've also subscribe to the AT&t UVerse.
Other concerns I have are: I can't play SACDs on my DVD Player
Video/picture is unsatisfactory
Pls, in plain english only, mostly on how and where to wire.
Thanks in advance to you all.....
Post edited by SoundTrip on
First Welcome to Polk Audio Forums.
Second I'm not sure where to start here... Way too many variables here.
Does the AVR have HDMI switching (I don't think so)
Does the TV have HDMI input?
Does the ATT UVerse have HDMI (inside note here I don't know so I'm asking
Do you use a programmable remote? And if so what brand / model.
(I ask this as the remove could do some switching on TV if AVR doesn't switch video)
So to sum up you what to use the highest signal input that you can use between any two devices. If the AVR can do switching all the better, but there's work around which work just as well also adding a cable here or there.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Are you using the analog(RCA) outs on your DVD player? SACD's can not be played over digital coax or optical cables. SACD's can sometimes be played via HDMI, but your player and receiver both have to be capable."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
My receiver doesn't have HDMI....DVD does.....
From the DVD player, run coax or optical to the receiver for audio, HDMI from the DVD player to the TV for video.
As I mentioned before, you'll also have to run RCA's from the DVD player to the receiver if you want to listen to SACD's.
I'd also recommend timbre matching all your speakers. Sticking with the same brand/line throughout for better blending/realism."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
