Keep blowing fuses on amp!!!
joker187
joker187 Posts: 25
edited September 2008 in Car Audio & Electronics
i have a 1800 watt kenwood kac-9152d amp 500 wattx1@4ohms 900wattx1@2ohms.i had the exact same amp before hooked up with a 8 guage wire and it work but stop. now i got the same amp and i hook everything up and nothing blows but i hook the ground up and amp fuses blow...WHAT AM I DOING WRONG PLEASE HELP.
Post edited by joker187 on
  • ben62670
    ben62670 Posts: 15,969
    Try one thread;) Stick to this one
    Ben
  • joker187
    joker187 Posts: 25
    :confused:will that stop the fuses from blowing on the amp? it's only when i go to hook up the ground?i still got the 8 guage rockford fosgate wire hooked up with a 60 amp fuse in it and the amp takes 30ax2...or do i need a bigger wire
    :confused:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    Sounds like you might have a bare spot in your power wire touching metal causing it to ground out thus blowing the fuse.
    Check your power wire make sure it's in good condition and not worn thru then check your ground over as well.
    Make sure your connections are solid with no lose strands of wire hangin around.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • exalted512
    exalted512 Posts: 10,734
    Do you have the amp screwed to metal?
    -Cody
  • joker187
    joker187 Posts: 25
    that could be but wouldnt my other amp not work?i hook my other amp up it workes fine. it's just a lighting audio amp 70 wattsx2@4ohms 180wattsx2@2ohms 340wattx1@4ohms bridged. i have the speaker parralel still so i just bridge them to the amp. and it's running fine. it's just the kenwood doesnt want to run? it's only when i hook the ground up it blowes fuses?the amp is screwed on top of the sub box....
  • MacLeod
    MacLeod Posts: 14,358
    If you can hook your old amp up to the same wiring and it works fine then as soon as you hook the Kenwood up it blows a fuse, then Id say youve got a bad amp. Might wanna exchange that bad boy.
  • joker187
    joker187 Posts: 25
    idk cuz i had the same amp and it was working fine but then that one messed up to...and it was the ground wire on that one that wouldnt. the only way it would work is if the ground was touching the amp. so could it just be the wire it to small....
  • Bruizer
    Bruizer Posts: 27
    I kept blowing fuses one time when trying to hook my Kicker SX1250.1 up, then I realized I had put the ground in the 12v and was trying to hook the power into the ground. :P
  • dalylaleahthor
    dalylaleahthor Posts: 322
    When is it blowing the fuse? When you hook up the ground? After you turn it on? Is it the fuse on the amp or the splitter? How many amps to you have hook up to your car? What is the total wattage of the two amps you are running?
    If it is blowing after you turn on the deck then it might be your power or ground. Not enough power not enough ground- 8 guage is too small to run two amp if it was up to me.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
