is this amp have enough power
Systems
I have a rockford fosgate 250 a.2 amp, i would like to hook up a single MOMO 10 in a sealed box. In the owners manual it states that in mono in to a 4 ohm load it will produce 320 watts x 1. I know amp manufactures like to streach the truth so any advice would be appericated. And if not what would be some other suggestions on what to put in a 2001 dodge durango?
Testing
Testing
Testing
Testing
Testing
thank you i kinda figured it wouldnt have enough power I will look in to the biger amp.Testing
Testing
Testing -
I would suggest a rockford fosgate bd500.1,a kicker dx700, or a mtx thunder 6500 as some of the smaller and cheaper amps you can get but always remember you can have more power in an amp and set it down low to get better clairity out of your subs
