my system
PolkClyde
PolkClyde Posts: 662
edited September 2008 in 2 Channel Audio
This baby is mighty old but work's ok I may need to re-do or un-do what ever words are right THE x-overs.Sometimes the left channel is louder than the right. Maybe earWax
PolkAudioClyde
Post edited by PolkClyde on
  • nikolas812
    nikolas812 Posts: 2,915
    Yikes!
    Thats a lot speaker for such a little room.
    Do you get any kind of imaging or separation out of the speakers in that room? Seems like it would just sound like on big speaker having them that close together.
    Nick
  • PolkClyde
    it sure is Nick
    PolkAudioClyde
  • PolkClyde
    That's why I don't play it much. it was in my bed room believe it or not.The room is long but as you can see not much width
    PolkAudioClyde
  • steveinaz
    steveinaz Posts: 19,546
    Sweet, that thing is a MON-STAH!
  • nikolas812
    It looks like a pretty cool system. It would be nice if you could open them babies up a little though.
    I guess you have to make do with you got. As long as you get some enjoyment out of it, thats all that matters.
    Cheers
    Nick
  • nikolas812
    I just noticted something.
    Has one side had a tweeter upgrade and not the other?
    Nick
  • ben62670
    ben62670 Posts: 15,969
    The width is really what is killing it. You really truly need at least 6' between them, and bare minimum of 3' on either side. It is being severely choked in that room. Also I see you don't have all the RDO's yet. I understand that, but I would find out which tweeters are the loudest, and place the RDO's there.
    Ben
  • haimoc
    haimoc Posts: 1,031
    Never experience these huge speakers.... Nice...
  • PolkClyde
    ben62670 wrote: »
    I have all 8 RDO's Candy licker or what ever his name is said that the originals were better than the RDO's so I'm comparing to see can I hear a difference.
    PolkAudioClyde
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Make no mistake, even though you already did by giving anything "he" said any merit, the RDO's are far better than the 2000's.
    heiney9 Posts: 25,492
    PolkClyde wrote: »
    Listening to his advice will lead down the wrong path. Do yourself a favor, save the headaches and use the RD0's. I don't how you could properly tell in a room that small anyways. Beautiful speakers and we all have different things to work with but that room is horrible for those speakers. Not trying to be detrimental, but having those speakers with those amps in that room is a shame. :o
  • lakesailor
    lakesailor Posts: 319
    PolkClyde wrote: »
    That’s a beauty old system. But kinda link of keeping a Great Dane in a Studio sized condo…..
  • zingo
    zingo Posts: 11,258
    Although, if you're going to run SDAs off of Carvers, they might as well be THOSE Carvers!
    I'm getting claustrophobic just looking at that picture!
  • PolkClyde
    I love you guys but agree with you all. it is a small room width wise :( I guess I need to put these boys back in storage. as for candy liker he doesn't seem well like here. I'm a newbie and trying to learn everything I can about audio and especially Polk Audio
    PolkAudioClyde
  • PolkClyde
    Let me say again I think I need to replace either the bass drivers in the right speaker or the X-Cross less output.....But All the drivers are working in the speaker in question
    PolkAudioClyde
  • fossy
    fossy Posts: 1,378
    Very nice system you have there -- I also have a very small space for my little system but I don't have the goodies you have. Crank er up , I say & enjoy.
  • SolidSqual
    SolidSqual Posts: 5,218
    Have you tried backing them completely into the corners to see how they sound?
  • PolkClyde
    SolidSqual wrote: »
    They are already back up to the rear wall if that's what you mean....the bass is deep. I Can't wait to put these bad boys in a larger room and listen like I Suppose to.
    I thank you guys for all your advice.
    PC
    PolkAudioClyde
  • leroyjr1
    leroyjr1 Posts: 8,785
    I think he meant spread them a part till they touch the walls
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Hey Clyde,
    I see you have been busy. Well what the guys said is right, given that, except for maybe Doro I am one of the biggest rule busters for SDA placement, the 6ft seperation and 3ft side wall distances along with 5 inches from the back wall are standard Polk set-up, but its just a starting point.
    I think that room is better than where you had them, at least it is dedicated, I would not put my speakers in storage, listen to them, if you like them cool, you might want to work a bit at room acoustics. You could send that pic to Ken Swauger and let him comment, I would put some bass traps in the corner, of course its only going to do so much and the fact that a bigger room would be better cannot be changed.
    RT1
  • lakesailor
    It really is a beauty system; but why not instead invest in some proper sized speakers for that room ?
  • tugboat
    tugboat Posts: 393
    It's not easy setting them up in most rooms (at least the rooms I've had). The best I'm able to do is 5' apart and 2' from side walls and 9" from rear wall. My "long" walls have doorways in them, so they're out of the question. Still, the sound and imaging is better than any other speakers I've owned.
    Can you move the left a bit closer to the side wall so it has the same side wall distance as the right? Might help with reflections. Other thing to try is acoustic tiles on the side walls to absorb as much of the reflection as possible.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  • miner
    miner Posts: 1,305
    How's the soundstage :)
  • PolkClyde
    lakesailor wrote: »
    I agree with the above quote. I'm a audiophile well that's How I see myself.This is a lot of fun unhooking re-hooking tweaking.To me the speaker System is the most Important link in the chain(I know that's debatable) therefore I will always throw money out there for A good loud speaker system. I also have the Polk 2A's. I like buying speakers.When I was home my dad use to get on to me for spending so much money on Electronics. AT 76 He still does.I'm going to buy some smaller speakers for this room.My 2A's are just for Djing.Yes I'm DJ From time to time. I have two turntables, Mixers,CD Players,Cassette players. MY musical taste is from James brown to Johnny Cash.Thanks Guys for all your help/advice.
    PC
    PolkAudioClyde
  • PolkClyde
    kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
    PolkAudioClyde
  • PolkClyde
    miner wrote: »
    The sound stage is great. Ben told me to put then in the corners wow got my sound stage back....you go BEN. That will have to do until I move into a bigger place. I just called KEN at Polk. I have other issues I'm dealing with as well. I got to go and do a little more tweaking.
    When I get my house The Krells will Prevail http://www.krellonline.com/ that's always been my Goal.
    Thanks guys
    PC
    PolkAudioClyde
  • PolkClyde
    miner wrote: »
    PolkAudioClyde
  • dacoupedeville
    dacoupedeville Posts: 83
    Did you switch the amps from side to side? I think is how this thread started.
    If necessary, dont fear the x-over upgrade. It is a simple and large improvement.
    HT: SRT's.....Pioneer SC95, Oppo 105D; ps4; Mitsubishi 1080p 82" DLP; DirecTV
    2 ch: SRS 1.2tl's.....Odyssey Stratos monos, Dynaco PAS pre w/Mods, Arcam DV-135, Music Hall MMF 5, AQ wires
    Bedroom: SRS 3.1tl's, RTA 8T (phantom center), Pioneer sc-lx701, Mitsubishi 1080p 82" DLP, DirecTV, ps3
    Car: SR 6500's.....Planet Audio HVT752 tube hybrid amps (2), Alpine dvd-a double din HU, two 12" Kicker's
  • PolkClyde
    What do you mean "switch the amps from side to side" Reverse them? thanks Brother
    PC
    PolkAudioClyde
  • PolkClyde
    I'm going to try a different set of speaker cables.....
    PolkAudioClyde
