Any Electricians
Grimster74
Grimster74 Posts: 2,577
edited September 2008 in Electronics
Okay, I've noticed for the last 2 days between the hours of 10 p.m. to midnight that the incoming power to my house has increased. Both of my HTS 5100's (upstairs & downstairs) usually display the power coming into the unit as 120-122, for the last 2 days between those hours, they have both been reading between 130-135 with the abnormal voltage light on. As far as all the gear downstairs, I've unplugged everything. My question is, should I call the power company and have them come take a look at it.
Saturday night around that time I noticed my house was hotter than normal as well. After doing some trouble shooting I noticed my outside ac unit wasn't working, no fan, no noise, just hot as hell when you touched the top of the unit. My step father owns his own ac company and is coming by today to have a look at the unit and from what I told him he said it sound like a capacitor could have blown on the unit. Could my sudden spike in electricity have been caused by the unit freezing up or could have my unit blowing a capacitor been caused by the sudden spike in electricity. Any help would be greatly appreciated. Thanks!
Rob
Post edited by Grimster74 on
  • Sherardp
    Sherardp Posts: 8,038
    call electrician. Something is definitely going on. If youre worried about it you could buy a voltage stabalizer and run that between incoming power and the monster 5100. I use transformers here and they keep a constant 120 to both monster Power Conditioners. Worth a google to say the least.
  • ajanzalone
    ajanzalone Posts: 128
    I am not sure why the higher voltages,
    but the lower voltage under 105vac and below is a brown out condition, that the utilities do at "High Load" hours .. when most AC or Heat is being used.
    Brown outs can cause a High Amp draw, especially on amp hungry equipment like an AC compressor.
    This can cause damage in some older AC units.
    Hope this helps
    Tony
    Audio Research SP5 Preamp
    Quad 405 Amp
    Pioneer Elite DV-48AV -
    Outlaw 950 preamp/processor
    Polk Monitor 10's
    Velodyne VRP 1200 Sub Woofer
    Success is having what you want ... but Happiness is wanting what you have!
  • Grimster74
    Well, my step dad just came by and said it WAS a blown capacitor, on his way to pick up a new one now. Figures, yesterday was the hottest damn day we've have in a month, 99 degrees with a heat index of 110 and my damn AC stopped working Saturday Night. Question now is, do I call the power company to find out whats going on?
  • Ricardo
    Ricardo Posts: 10,636
    I would call and let them know you are getting those high voltages.
    SOPA
  • Grimster74
    Okay, called the power company to make sure they note on my account about my power issues. The gentleman I talked with explained to me that chances are when the capacitor blew, it had to discharge all the stored power it was holding so it was probaly back fed into the house. Told me to keep an eye on it and if it does it again to call them back and they will come out and place something on the box outside that keeps track of the power coming into the house so that way they can tell if it's the power companys problem or if its time to call an electrician. Anyways, AC has been fixed and power company has been called and noted so hopefully this was an isolated incident. Thanks guys!
    Rob
  • Deadof_knight
    Deadof_knight Posts: 980
    OK blown capacitor where ? on the a/c unit . Thise capacitors are smalls and would discharge fairly quickly. Or are we talking about a capacitor on the incomming line those banks are fairly large I have no clue how long they would take but I cant imagine much more than a few hours. I use to work on the high voltage crews for the military base here. Usually its a low voltage problem not a high .... sounds fishy!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Power companies use caps on their lines in the field, to balance out voltage to loads. I had an issue 20 years ago like that high voltage, where the electric company placed a chart meter on my line. They did find high voltage and needed to remove some caps in the line to rebalance the voltage.
    I'm not a electrician or lines man by trade, so my terms may not be 100% just my $.02
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • ben62670
    ben62670 Posts: 15,969
    If the AC cap blew there might be a sudden surge. It certainly would not cause a steady over voltage situation. I would call again, and let them know they will have to replace a lot of expensive rear if this continues. 130 is not normal.
    Ben
  • Lowell_M
    Lowell_M Posts: 1,660
    Shouldn't the HTS shut power to the HT down at that high a voltage?
    A capacitor absolutely would not raise the voltage of your house for an extended period of time. Something is up.
    If you have any electrician friends, or need to call an electrician... ask them if they have an IDEAL Industries Voltage Performance Monitor (61-830)
    http://www.idealindustries.com/prodDetail.do?prodId=61-830
    They cost around $600 ish, but are exactly what you need to track down what is going on with your power.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Marty913
    Marty913 Posts: 760
    ben62670 wrote: »
    I agree BUT it would not be unusual to see a 5-10% fluctuation in voltage level at any given time. With an optimal stable input of 120 it would not be unusual to see 115 or 130 occasionally. The key word is occasional, and I might add "short duration". If you are running 130-135 for hours, something is wrong. With the associated surge when air compressors cycle on and off, it certainly could have contributed to the A/C problem. The A/C compressor would be 220-240 so it could be seeing 260-270 plus the normal on/off surge.
    I'd keep a close eye on it and make sure the power company has your concerns on record. A call to your insurance guy/girl might also be a good idea.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
