70's mancave update...phase II
steveinaz
Got the floor epoxy down this weekend, see the before and after pics. Pic 3 isn't very accurate, the floor has more of a blue cast to it, like the 2nd pic. I used Behr premium 2-part epoxy:
Post edited by steveinaz on
Looks like a H/T room in the making if you ask me, LOL! Looks great Steve.
RobMoney Talks, Mine says Goodbye Rob!!!! -
Looking good,,if you're gonna have a blacklight,,lemme know,,I've got a "dayglo" poster I'll send you.JC approves....he told me so. (F-1 nut)
Dont forget the carbon monoxide detector for that room....could be your best investment in gear by far
The first rule of Fight Club is you don't talk about Fight Club -
Are the curtains a permanent feature for this room? I was thinking of a similar separator for my basement.
YankPolk Monitor 7
Polk Atrium 55 -
I know it sounds good too.
Looking great Steve!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Yank
Yep, they do the trick. I thought about framing some walls--but I can't justify the work/expense. The 70's mancave is basically a "duck-out" room when weather gets bad on the patio; and for winter time.
One of my main goals with this room is to NOT make it look too contrived. I want it to look like a 15yr old had to scrounge the basement to complete it. I don't want it to look like a livingroom of the 70's. The curtains help portray that look, as well as the mis-match furniture that will be in there. If everything matches/coordinates--it won't look right. Aside from the TV/DVD, nothing else in the room will be anything you could have purchased after 1979--that's the goal.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Looks great, I wish I could do that with my Garage, but have to keep the vintage caddy out of the elements
Looking good man. When is the projected finish date?
Probably 2 more weekends and she'll be done.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
NIce job overall.
If I may ask, how difficult is it to work with that epoxy stuff *? I am thinking of
doing part of my basement/workshop area with it, as well as the garage. Cost/sq.ft?
Any info appreciated!
Harry
* No affil.
http://audiomilitia.proboards.com/ -
Harry
I used Behr premium 2-part epoxy (silver/gray) from home depot. It was $69 per kit. 1 kit will do a 1 car garage easily (250 sq ft). We have a 2 1/2 car garage (apprx 550 sq ft) and I bought 3 kits, but only used 2 1/4 kits. This particular brand has an 8-hour hardening time, so you don't need to rush.
-strip prep the floor (etch with acid if necessary, this comes in the kit)
-let the floor dry completely
-tape off your base boards
-have 1 person do the trim, while you roll the epoxy
-roll about a 3x3 section then drop the paint chips (if you want to use them)
-dries to the touch in about 7-8 hrs, light foot traffic after 12hrs, give it 36hrs before pulling cars on it
After the prep work, it took us about 3.5 hrs to get the floor painted.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Many thanks for the info, as well as relating your experience with it.
Maybe I'll post pics when I'm done (prob. 3 or 4 months from now
). So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
No problem; if it hadn't been 95 degrees Saturday, doing the floor wouldn't have been so bad.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Arizona has a "winter"?Expert Moron Extraordinaire
Yep--not very long, but we can get in the low 20's. Nights here can very chilly in spring/fall/winter. Keep in mind we're at 4800 ft elevation--Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks dude. My Pioneer HPM 40 speakers arrived yesterday, they look excellent! Can't believe a 30 yr old speaker could still look this good.
I'll hold all other pics until she's complete. Stay tuned...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
