LCD Wall Mounts
xsmi
Guy's,
I am the band director at a small Catholic High School in Toledo, OH. I have purchased (2) 24" iMacs (25lbs) for my practice rooms as we are installing SmartMusic so the students can get more out of their practice. I would like to mount the imacs to the wall both for aesthetic purposes and the fact the rooms are a little small and I do not want to give up the floor space to a desk. I am looking for something small but strong. The walls are cinder block, I don't know that that matters from mount to mount but I want to be thorough. I do need it to tilt. I do not want an arm because I am concerned with it coming in contact with the door. What have you guys used? What would you suggest I stay away from?
xsmi
xsmi
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
Larry
2nd monoprice. It's what i use for a 40" LCD with no issues...great mounts, great prices.
try looking up and finding a mount by Vantage Point. Low profile mount, gives you the ability to slide the screen left and right, tilt and also allows you to lock the screen down for security using a special tool provided.Shoot the jumper.....................BALLIN.............!!!!!
Thank you! The prices were so low, I had to see if they were the shipping prices.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
