1.2TL crossover design question
  • Ricardo
    Ricardo Posts: 10,634
    edited September 2008
    tugboat wrote: »
    I have the same setup as you. The bypass and 22.5 resistor go nowhere. They are connected to a section that has no other components or connections. My 12uf is connected directly to the output connection as well w/out a jumper. What I'm wondering is if this 22.5ohm is meant for the bypass only. Even with the jumper, the resistor wouldn't be in series with the 12uf like all the other outputs.
    Hopefully someone here will chime in.
    Look at the schematics; that 22.5 ohm resistor (and the bypass cap) should be in parallel with the 12uF cap. If you add a jumper between R2 and P3 you will achieve this.
    As I mentioned in the other thread you started, your best bet is to post in the troubleshooting area for Ken to see, or even beter, you can try it with and without that jumper.
    SOPA
