Up Date or Up Grade equipment?
ajanzalone
ajanzalone Posts: 128
edited September 2008 in 2 Channel Audio
I have "Quad 405" dumping amp. 100w RMS
I can up date or replace key capacitors, "diodes and resistors and opamps" for about $260.
Of course the Quad people say it is an amazing up date!
Or would I do better to find a newer quality Amp, maybe 10 years or less, in age?
Any thoughts?
Tony
Audio Research SP5 Preamp
Quad 405 Amp
Pioneer Elite DV-48AV -
Outlaw 950 preamp/processor
Polk Monitor 10's
Velodyne VRP 1200 Sub Woofer
Success is having what you want ... but Happiness is wanting what you have!
Post edited by ajanzalone on
  • ben62670
    ben62670 Posts: 15,969
    Is that a quote to have it done for you? little high. Quad 405's have a fallowing, but...
    Ben
  • dave shepard
    dave shepard Posts: 1,334
    I feel that if you think you need to change the parts inside and amp to tweek the sound you would be better off finding a differant amp. You can do part swaping to the inside of the amp but you are also changing the design of the amp and it might not perform correctly and the sound might not be what you are looking for. IMO it is best to find something that will perform the way it was designed to fill your needs you just have to do some leg work and listen to a few, the choices are endless.
  • Early B.
    Early B. Posts: 7,900
    Buy another amp.
    "God grooves with tubes."
  • ajanzalone
    ben62670 wrote: »
    Ben
    yes a quote from a recognized Quad tech
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ben62670
    I studied the quad 405 a bit. I have couple boards to build here, but with gain clones so cheap I abandoned the 405. minor mods can help, but that is a 70's amp that just really isn't worth dumping cash into.
    Ben
  • ajanzalone
    ben62670 wrote: »
    Yes, I was suspecting a newer unit would be more cost effective.
    It is overwhelming though, trying to figure out what is high end and yet not too old, to spend my $$$ on.
    I don't want to get something that will also need immediate up dating.
    But cost is a factor 1k or less .....
    but I don't want to downgrade either as this Audio Research/ Quad/ Polk 10 setup still sounds great.
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ben62670
    Check out George Daniels GFA-535. I am a friend of his, but it is a good price. Adcoms are true to sound.
    Ben
    Ben
  • Lowell_M
    Lowell_M Posts: 1,660
    If your budget is $1k or below, I would look higher into the ADCOM range and find a GFA-555. You can usually find them for around $300. Or..... I don't think you could go wrong with a Marsh A200s either for around $500-$600. Ether way, if you get it and don't like it you can sell it and you will only be out the shipping cost.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • candyliquor35m
    candyliquor35m Posts: 2,267
    houston cl: Carver TFM-55 Power Amp, 380 watts x 2 - $400 (Sealy)
    http://houston.craigslist.org/ele/826690236.html no affil.
    you could see if the guy is willing to ship it. I can go check it out for you.
  • ajanzalone
    mmmm where is it located, i am in florida?
    I noticed a lot of the Carver TFM-15CB for sale also... 100w i think?
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • candyliquor35m
    ajanzalone wrote: »
    Tony
    sealy is about 30 miles west of houston
  • ajanzalone
    I e-mailed him on this unit
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • TroyD
    TroyD Posts: 13,124
    For 1K ......you can do better.
    Stretch that a bit and there is a nice Krell in the FM. Look on A'gon and you can usually pick up a Classe 100wpc amp for less than that.
    Lots of options in the ~1K price range.
    BDT
  • schwarcw
    schwarcw Posts: 7,358
    I second what Troy is saying. That Krell is an excellent amp.
    Carl
  • candyliquor35m
    be patient and wait for something in the $500 range. A krell driving some polk 10's is overkill and a $500 amp is a helluva lot easier to resell than a $1000 amp. The $500 savings can be used to buy a nice warm tube pre like a cj-7 or 10al with tf's in it.
    F1nut Posts: 51,934
    Once again, that's just a whole lotta bad advice.
    The better the amp, the better those speakers will sound.
    Ajanzalone, try something new, only way to know.
    F1nut Posts: 51,934
    Sealy, TX.......I've been there, no reason to ever return. Although, the Sportsman's Lounge does serve some pretty damn good quail. If memory serves, you get 3 quail for something like $10.00 and on Friday's, all the quail you can eat for the same.
    They make you check your piece at the door, regardless.
  • snow
    snow Posts: 4,358
    How many quail can you eat? :D
    REGARDS SNOW
    F1nut Posts: 51,934
    More than I should.
  • ajanzalone
    Sealy, TX.......t 3 quail for something like $10.00 .
    mmmmmmm 3 Quail? ......... is that Peak or RMS ........ :)
    never leave your piece at the door:eek:
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ben62670
    Quail is awesome, but they are small. After having quail you won't ever want to touch pheasant again.
    Ben
    Ben
  • ajanzalone
    I e mailed and he replied quickly, he would ship ......
    I inquired as to the MFG date & Condition? ...... but no reply so far ......
    Funny how people get quite when you ask specifics ....:confused:
    It looks a bit rough on the Craig-list Photo http://houston.craigslist.org/ele/826690236.html no affil.
    I believe I should go to 150w minimum or higher, (really + 200w) on the next unit .....
    After some slow investigation, I have narrowed the choices to:
    Adcom GFA 555 II
    Adcom GFA 555
    Rotel RB 1080
    Carver TFM 25
    Carver TFM-42
    Carver TFM-55
    SUNFIRE SERIES II
    Any thoughts on these for my Polk 10's
    **(Music Use ... Grieg Piano Concerto , Crosby Stills Nash & Young, Neil Diamond - love the prologue in the Hot August Nights, Eagles, Al Jerou, George Jenson, ...etc)
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • Hawkeye
    Hawkeye Posts: 1,313
    Stretch for the Krell.
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • candyliquor35m
    ajanzalone wrote: »
    Adcom GFA 555 II
    Adcom GFA 555
    Rotel RB 1080
    Carver TFM 25
    Carver TFM-42
    Carver TFM-55
    SUNFIRE SERIES II
    Tony
    both my tfm-42 and tfm-45 I had to send in for routine maintenance ($200) after I bought them. Cap replacement, cold solder repairs, bias adjustment, etc so keep that in mind.
  • ajanzalone
    ajanzalone wrote: »
    I e-mailed the "Quad repair center" and explained I have decided to upgrade my amp to a newer higher end product, rather than update my Quad 405, for a more cost & audio effective, improvement ..... etc
    This was the reply i received:
    "So many of these so called "Audiophiles" speak without ever having dealt with products.
    I own extremely high end audio equipment and a modified 405 is one of the best.
    As a matter of fact dual mono Quad 405's are the best I have ever heard."
    I am so confused .......:eek:
    Or is this a American/Brit thing?
    But I have time to weigh it all out!
    Tony
    Quad 405 Amp
    Polk Monitor 10's
    F1nut Posts: 51,934
    Nobody likes their baby called ugly.
    I like the sound of Quad's speakers, their amps, less so. I like the older KSA Krell amps, their newer stuff, not at all. Perhaps a modded Quad amp is much better. I mean, that's what mods are suppose to do, make it better.
  • ajanzalone
    Well I would like to believe that a mod could work.....
    but it is still only 100w amp and it is hard to accept that the newer electronics would not
    surpass 1977 technology of even a very high end vintage product?
    Tony
    Quad 405 Amp
    Polk Monitor 10's
    F1nut Posts: 51,934
    100 wpc amp can be more than enough power. Of course, that's somewhat dependent on how efficient the speakers are, but it also depends on the amp. Is it Class A? Is it high current? Is that 100 wpc rating very conservative?
    There are plenty of vintage pieces that still sound great and are highly sought after. Check out the price of a Marantz 8B tube amp.
  • fossy
    fossy Posts: 1,378
    that is a darn good price on the TFM -55 if it's working properly-- last couple that i watched on e-bay(eprey ) went for $560 & $600 ---
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=110281564610
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150285257665
    another decent used amp is parasound
  • ajanzalone
    100 wpc amp can be more than enough power. Of course, that's somewhat dependent on how efficient the speakers are, but it also depends on the amp. Is it Class A? Is it high current? Is that 100 wpc rating very conservative?.
    I believe it is Class A/ current dumping, a very unique Audio design.
    quoted from stereophile.com
    "In "current dumping," a low-powered, low-distortion class-A amplifier is used to control the amount of current passing through a pair of heavy-duty "dumping" transistors, and it is the latter which provide the driving power (100Wpc) for the speakers."
    The Quad up grade tech has also shown interest of buying or trading for it from me, if I don't want to update.
    I do not know the efficiency of my Polk 10's
    Tony
    Quad 405 Amp
    Polk Monitor 10's
