CD/DVD burning
JoshParsons84
JoshParsons84 Posts: 565
edited September 2008 in The Clubhouse
Hey guys I'm looking for a free real easy-to-use good quality CD burning program and etc. for a DVD burning program. What do y'all suggest for the two?
Post edited by JoshParsons84 on
    heiney9 Posts: 25,503
    DVD Fab-Platinum Ed.
    billbillw Posts: 7,800
    I don't think either of those options above are 'free' in the long run.
    If you are looking at free programs, you sometimes need to have separate ripping and burning software especially with DVDs.
    For ripping Audio, nothing beats EAC. You can rip to your PC in FLAC, .wav, (or MP3 if you want lossy) and the software will let you burn too.
    For ripping DVDs, DVD Fab Decrypter works best in my experience.
    For shrinking/authoring/burning, I suggest you read the guides at Doom9.org.
    I personally thing that the Nero Suite of software is well worth the asking price.
    It has practically everything you need to author, compress, encode, burn just about any type of audio and/or video disc. The only thing they don't include are the 'rippers' (I'm sure due to fears of lawsuit from the studios). Nero Recode alone is worth it for shrinking/burning DVD backups.
  • WilliamM2
    WilliamM2 Posts: 4,808
    If you are just talking about burning discs, with no need to un-encrypt etc, this one works fine:
    http://cdburnerxp.se/
    DVD Fab is an excellent straight forward DVD ripping/authoring program. Not sure if it was free or not. But I used to use DVD Shrink and DVD Fab is leaps and bounds nicer and more user friendly.
    But as others stated "freeware" is going to be limited on the functions it performs. I've found in the end if you even get a little usage out of it paying is the best option.
    FWIW
    P.s DVD Fab Platinum overrides encrypted discs as well as allowing you to delete certain parts of the DVD so it doesn't have to auto shrink to fit a DVD9 on a DVD5
  • avelanchefan
    avelanchefan Posts: 2,401
    Are you guys kidding? Sorry but I will have to disagree with all of those choices. The most stable burning program around is Image Burn. Its free, it's uber small, and it will burn anything.
    I have personally burned over 200 dual layer DVD's, and well over 500 DVD's with this program. Not once have I ever had a crash or an error. The only error I have ever got with this program is when the DVD media I had chosen sucked. Seriously do not look any further.
    http://www.imgburn.com/
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
