Should a CRS sound a LOT better than a Series 1 SDA?
  • ben62670
    ben62670 Posts: 15,969
    edited September 2008
    The dimensional tweeter issue can be fixed real easy. Unhook it and see if you like the SQ more. The highs will be a little low, but you can fix that real easy on the XO.
    Ben
    Ben
  • Rivrrat
    Rivrrat Posts: 2,101
    TroyD wrote: »
    CL35 has no idea what he's talking about, pay him no attention. He wouldn't know good sound if it crawled up his leg and bit him on the ball bag.
    BDT
    Now that was funny.:D
    My equipment sig felt inadequate and deleted itself.
  • ben62670
    Rivrrat wrote: »
    And it is my new sig!
    Ben
  • Bigerik
    Bigerik Posts: 149
    Face wrote: »
    Welcome to the madhouse.
    Thank you!
    Seems to be much truth to that description. Lots of good info tho too. Now, sorting out the good stuff is going to be the challenge.... :)
    As my room is a little on the bright side anyway, losing one tweeter and replacing the other with a 194 seems like a good start. With some crossover rebuilds too.
    BTW, anyone running tubes with their SDA's?
    F1nut Posts: 51,719
    Yes.
  • Bigerik
    Bigerik Posts: 149
    Yes.
    Thanks!
