Replaced jumpers 1.2TL
tugboat
tugboat Posts: 393
edited September 2008 in Vintage Speakers
Well I was going to make some new jumpers out of quaility wire and connectors, but decided to do the following. From my end there doesn't seem a downside to doing this. If anyone feels this isn't a good approach, let me know (and why).
Picture is a bit blurry. Can't quite get the macro function to focus properly.
Thanks!
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Post edited by tugboat on
  • tugboat
    tugboat Posts: 393
    That came to mind, but my wire is stranded, not solid. I had some extra banana plugs anyway. I ordered new plugs for all my speakers and receiver and all was going well until I tried them on my LS/FX surround speakers attached to the wall. Seems polk didn't recess the post enough to allow banana plugs while hanging on the wall. The plugs would have to be less than 1/2" long after being inserted. I think I might be able to get away with using the crimp/solder plugs (they seem shorter overall).
  • zingo
    zingo Posts: 11,258
    That looks like a good idea tugboat and nice thinking! I wouldn't suggest the naked wire unless you tin it because of oxidation.
  • tugboat
    tugboat Posts: 393
    zingo wrote: »
    I surprised myself on this one, but like they say....Even a blind chicken finds a piece of corn now and then. :D
    I'm not an expert on reactive metals, but I seem to recall reading somewhere that copper and gold react less to each other than tin and gold do. Could be wrong, but at least the way I did it will allow me to keep an eye out for corrosion.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    I hooked mine up in a similar way.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • tugboat
    tugboat Posts: 393
    Your setup was also something I was thinking of, but I know if I went that route it would be more effort to unplug them (I can get pretty lazy). :D
    For the IC cable, I used a single 12ga wire and soldered on pins I removed from an old RCA cable. I was told that unless you're using the AI-1 with non-common ground amps, the blade doesn't have a function other than support for the pin. Seems to work well and I have enough cable to try and hide already.
