LS 50 speakers
Jeffrey D. Mead
I have a pair of LS 50's and they are in great shape except for the front plastic grill portion outlining the cover. It appears that the plastic molded black plastic is actually blue plastic with a black vinyl streched over it. This vinyl has shrunk exposing this blue plastic background and it really does not look good. It does not look like an easy fix but I thought I would ask to see if anyone had any sugestions. Thanks, Jeff
Post edited by Jeffrey D. Mead on
Can you post a pic?Political Correctness'.........defined
President of Club Polk -
Same problem here on one of my LS90s. I just noticed it when moving recently. I can almost stretch it back to it original place but I'm not sure a glue would hold it and it would be a oneshot chance of using that method.
I'll try a pic soon.
DJoriginal Monitor 10Bs
Original Rosewood LS90s,
SDA 3.1TL,
LS/FX
CS350
NHT 2 x SW3P/SA-3
B&K Ref 30,ST125.2,AV5000[/FONT] -
Jeffrey D. Mead wrote: »I have a pair of LS 50's and they are in great shape except for the front plastic grill portion outlining the cover. It appears that the plastic molded black plastic is actually blue plastic with a black vinyl streched over it. This vinyl has shrunk exposing this blue plastic background and it really does not look good. It does not look like an easy fix but I thought I would ask to see if anyone had any sugestions. Thanks, Jeff
you mean the frame which goes around the front with the polk name on it and held in place by those lil pins that love to break off? -
Go to a place that services Polk speakers and see if you can purchase a replacement piece. I was able to obtain one about three years ago for one of my LS70's. Good luck!!Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
Cambridge Audio 640C V2 CD Player & Dacmagic DAC
Rega Planar 3: Deep Groove Subplatter, P3 Motor
upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
