Cross over
I would like to upgrade my crossovers in my Polk 1.2's can anyone help me with this. How it's done and where can I buy the parts. If anyone got a video on how its' done would be helpful. Hey Ted where are you?
PolkAudioClyde
Post edited by PolkClyde on
This might help get you started....
The links do not underline anymore, so any threads that read like there should be a link in them, scan around with your mouse and you may find the link you are looking for.
Clyde,
Use the search function and do a search on SDA crossover upgrade. There are several threads with pics.
here is a link to get you started
http://www.polkaudio.com/forums/showthread.php?t=69245&highlight=sda+crossover+upgrade
RT1
