What's with the Chinese?
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    Have some cheese with your wine guys. I dont even watch them anymore nothing but a big argument if you ask me.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • exalted512
    exalted512 Posts: 10,735
    edited August 2008
    Shizelbs wrote: »
    Can I assume you did not see the American player lay out the Chinese catcher on a play at the plate? He bowled him over when a slide would have done just fine.
    Getting beaned is part of the game.
    What's easier to get out of the way from, a 6 foot tall person traveling 15 mph or a 4" baseball traveling 80+ mph?
    Running is faster than sliding, so if you have to run over someone to get to the plate, thats acceptable.
    BeaNing 6 different people in an Olympic game (aka, best of the best), is not.
    -Cody
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2008
    Its acceptable if you need to do it (a slide won't cut it/the catcher HAS the ball and will tag you.) Its **** to lay out the catcher when the ball is somewhere on its way to him and he isn't looking at you.
    Its the umpires fault if they got up to six bean balls. Its their job to control the game.
  • AdamRagland
    AdamRagland Posts: 521
    edited August 2008
    you dont run to homeplate to be faster. sliding is indeed faster. not that i am defending the chinese but you run THROUGH the catcher to knock the crap out of him causing him to drop the catch....
  • Demiurge
    Demiurge Posts: 10,874
    edited August 2008
    It's absolutely acceptable to knock the crap out of a catcher if he/she is blocking home plate. The object is to make the catcher drop the ball, and if they don't have it yet, too bad. It's not the job of the runner to watch where the ball is as they're running bases. That's why we have base coaches.
  • exalted512
    edited August 2008
    Demiurge wrote: »
    thank you.
    Sliding is NOT faster...if it was, everyone in track would be sliding through the finish line. Sometimes you're not aware of where the ball is and you just want to get there as fast as possible. Been there, done that many times.
    -Cody
  • Demiurge
    edited August 2008
    What's with those beeps and other crap going off tonight during the gymnastics routines? Almost sound like cell phones.
  • Demiurge
    edited August 2008
    NM, it apparently is a buzzer telling them they have 10 seconds left.
  • Sami
    Sami Posts: 4,634
    edited August 2008
    exalted512 wrote: »
    thank you.
    It is, if you do it the proper way, head first. :)
  • Jstas
    Jstas Posts: 14,985
    edited August 2008
    The reason anyone slides in baseball is because the ONLY base you are allowed to over-run is 1st and that is ONLY after you hit the ball and are running your little heart out to get to first base and gain a base hit. If you over run any other base and you lose contact with the bag and someone tags you, you're out.
    The reason you run over the catcher is if he is blocking home plate. Then you can plow him down, hopefully he will drop the ball. Your other option is to slide and hope that your drastic change in speed and the smaller area (i.e.: your leg vs your torso) makes the catcher miss the tag. Once home plate is tagged safely, the run is over and the score is logged. You can't over-run home plate because you can't occupy home plate.
    If the catcher is not blocking home plate and doesn't have the ball yet and you plow him down, it can be a interference call (yes they do have them in baseball but it's rare to have it called). If he is not blocking home plate and you leave the base line to plow him down, as a runner, you are automatically out.
    There are alot of rules but plowing down the catcher, with or without the ball, is, acceptable under quite a few circumstances. Sliding though, is decidedly NOT faster. It is intended to stop you faster without having to slow down your stride and therefore make you susceptible to getting tagged out. It's an avoidance technique, not a speed thing.
    Expert Moron Extraordinaire
  • Shizelbs
    edited August 2008
    If the catcher has home plate blocked, knock the dude out. But if he's just standing on it waiting for a throw to come in from the outfield and you lay him out you'd be wise to watch for a bean ball.
  • Shizelbs
    edited August 2008
    Oh, Usain Bolt is a stud.
  • Demiurge
    edited August 2008
    As part of a news report I heard the Chinese were paying "cheerleaders" to sit in the stands and also keeping normal crowds smaller to prevent government protests. Anyone have a link to this allegation from a reputable source? I was in my car when I heard it.
  • seeclear
    seeclear Posts: 1,244
    edited August 2008
    NBC reporting that the age issue of the chinese girls gymnastics team is being investigated by the IOC and may result in medals being stripped from the chinese. FWIW
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
