PS3 Question....
shawn474
Just a quick question and any help is much appreciated. I just bought Army of Two for my PS3 and in the tutorial section, the instructions that pop up on the screen are very blurry, to the point where I can't determine the difference between L1, L2, L3, etc. on the screen. Maybe I need glasses, but I thought this may be a setting issue. Nothing else seems to be blurry except for the subtitled directions.
Thanks,
Shawn
Thanks,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
Post edited by shawn474 on
What's the question?
If I remember correctly the XBOX edition had the same issues. I ended doing what I always do, press all the buttons till I get the right one to work.
Just wondering whether or not I have the settings wrong on the PS3. I have never had a problem with it before this particular game. Maybe a display setting or something like that.
It sounds stupid but it is driving me nuts.Shawn
Front: Polk LsiM703
Rear: LSI fx
DVD Player: Sony PS4 -
Are you playing on a HDTV? Some games have very small writing thats hard to read unless your using a HDTV.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
Subwoofer: Mirage Omni S10
TV: Sharp Aquos 42" 1080p LCD
Receiver: Onkyo TX-SR805
Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3 -
It is a rear projection HDTV connected via HDMI. Like I said, I haven't had a problem with any other game except this one. It sounds stupid, I know. But, it's annoying as hell.Shawn
Front: Polk LsiM703
Rear: LSI fx
It's a problem with the game.
I had the same problem
____________________
Pool: Atrium 60's/45's -
Did you resolve the problem?
Madden,
It's an in game issue, I do not think there is a resolution, its just something you have to deal with. It sucks I know, but like i said before I had this issue with the 360 version also.
Personally this is what EA does. They make a great game but they screw up the little stuff that makes the game unenjoyable, or frustrating.
I found that Army of Two was great, but I cannot remember what mission I got to and I said screw it, and stopped playing it, I am pretty sure I was near the end. -
