polishing the ends of cables
Norm Apter
Norm Apter Posts: 1,036
Oh, boy. I realize that for cable non-believers the following post really just opens itself up to all kinds of "snake oil" jokes, especially considering that Audioquest has several lines named after snakes.
But here goes --
I just read this review of Audioquest Diamondbacks on Amazon.com:
"It sounds crazy, but cables matter. I have used a dozen different ones and they have gotten better and cheaper over the last dozen years. Note, they are directional. You will see arrows pointing in the direction of the signal.
But it is all to no avail if you do not keep the ends polished, and then lubricated with a little oil to finish the connection. This goes for polishing the sockets on the components. It even goes for the power cords. Try it. Take everything apart, polish all the ends on every component and cable and finish with oil and see how the sound improves."
I had never heard of polishing ends or using oil on these connections before. Does anybody do this? If so, what exactly do you use and how often do you do it? Don't want be the start of another great cable debate. Just trying to see if other folks also do this.
And despite the great temptation, please no "snake oil" jokes...ha, ha.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    Oh my God now that is some funny stuff. You have got to be kidding me. Polishing your connectors that is one of the most ridiculous things I have ever heard.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited August 2008
    Well a lot of people do use Deoxit to clean, and keep the ends from corroding. None of my cables or connectors have ever corroded though.
    Seems no more ridiculous than other claims.
  • Face
    Face Posts: 14,340
    edited August 2008
    The only time I would polish a connector is if it was from a vintage item and hazed over or slightly corroded. Just use DeoxIT, you'll be fine.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited August 2008
    I would say deoxit or no-ox can't hurt anything. Oxidation will degrade a signal eventually.
    I do dc power work for a baby bell, and we're expected to use clean ends and no ox on our connectors, just to avoid oxidation, although, I haven't bothered to use it on any of my stuff.
    Also, supposedly gold doesn't oxidize, so there's something else to think about.
    My equipment sig felt inadequate and deleted itself.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2008
  • Norm Apter
    edited August 2008
    Thanks for the info.
    I just had a look at the backside of my tuner which I bought used (its 2-3 years old) about a month ago. After pulling off the RCA connectors, I noticed that there is some black smudging on (what appears to be gold-coated) the line output connectors. Might this be a sign of oxidation? (though Rivrrat stated that gold supposedly does not oxidize so maybe this is just tarnishing from long term use of RCA cables???)
    As for the Caig DeoxIt, I've been doing some searches of threads on CP which have discussed it. For those of you who have used it, would you apply the brush stuff to both the output and input connectors on your components AND the ends of RCA cables, or just one or the other?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Face
    Face Posts: 14,340
    edited August 2008
    Everything but optical. :D
  • snow
    snow Posts: 4,358
    edited August 2008
    Have you ever noticed how your car/truck wont start and you go look under the hood and see how the battery cable and or connector is corroded? Same difference in my oppinion.
    A clean cable/connector is a happy cable/connector :p
    REGARDS SNOW
    F1nut Posts: 52,007
    edited August 2008
    Gold does not oxidize, period.
    Oil??? NEVER!!!
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Not even snake oil?
    Ben
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2008
    what about blinker fluid for the leds....
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2008
    I've always found that stuff way over priced for the minimal brightness increase realized. Windex will reveal the same clarity and photon tranparency at a much lower price ;)
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited August 2008
    Face wrote: »
    +1
    But then again it can't hurt.
  • mmadden28
    edited August 2008
    Oil??? NEVER!!!
    Pure gold doesn't, but what about the level of gold plating that is put in mass manufactured jacks, etc.?? I would also expect that depending on how often the equipment is changed around, some of that gold plating might wear away.
  • mmadden28
    edited August 2008
    ben62670 wrote: »
    Not even snake oil?
    Only the Papuan Taipan oil. Very hard to get though and thus very expensive. Also requires refrigeration-no good in most third world countries.
    F1nut Posts: 52,007
    edited August 2008
    mmadden28 wrote: »
    If the gold plating is that bad, that thin or that worn away, polishing isn't going to help matters.
    heiney9 Posts: 25,509
    edited August 2008
    Norm Apter wrote: »
    But here goes --
    This isn't at all far fetched. A very well respected audio guru who won't debate the issue of cables with his components states he finds that the connection is just as important than the type of cable you use. CAIG as well as a few others make lubrication, anti oxidation and cleaning solutions and it is a good idea once a year or so to clean and lube all your connections. Oxidation, air born contaminants, dust, cigarette smoke, etc collect and "gunk" up connections.
    He goes on to state that keeping connections clean and secure goes a long way in getting the most performance from your components.
    edited August 2008
    WilliamM2 wrote: »
    William you can't really see the oxidation. It's not like when your car battery terminal gets all the nasty green stuff on the (+) lead. If someone doesn't want to spend the $20 on CAIG products you can use 90% Isopropyl alcohol to clean the male and female ends every year or so. For me it's not about snake oil or expensive cleaners. It's about common sense knowing that over time the crap in the air will eventually gunk up the connections.
    Ever had a nice piece of real wood furniture and not polished it for a few years. The first time you do using a white rag it become black from all the contaminants in the air that settled on the surface. Do you think these air born contaminants just skip over audio connections?
    edited August 2008
    Rivrrat wrote: »
    Your right, gold doesn't oxidize but it can still collect other air born contaminants. It's just good practice to clean all connections about once a year or so. You can use a .99c bottle of rubbing alcohol if you don't want to spend $20 on a CAIG or similar product. CAIG stuff works extremely well and I've had the same 2 step kit for 5 years as it doesn't take much to clean and lube connections.
  • WilliamM2
    edited August 2008
    heiney9 wrote: »
    How do the airborne contaminants settle into the surface where the connectors meet, when there is metal to metal contact?
    I don't see anything wrong with keeping the connectors clean, can't hurt anything, but as far as being audible? I guess if some un-named but very respected audio guru, who refuses to discuss it says so, then it must be true.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited August 2008
    WilliamM2 wrote: »
    I now have coffee all over my keyboard....:p
  • zingo
    zingo Posts: 11,258
    edited August 2008
    heiney9 wrote: »
    William you can't really see the oxidation. Do you think these air born contaminants just skip over audio connections?
    WilliamM2 wrote: »
    Didn't we just do this? :rolleyes:
  • xeb
    xeb Posts: 31
    edited August 2008
    i solder mine :D
    only to keep the ends neat though ;)
    edited August 2008
    WilliamM2 wrote: »
    I know you are not that stupid.......do you really believe that at the connection it is sealed so tight that nothing could possibly get in there? Look I'm not saying avery 6 weeks this needs to be done. It's a good practice to follow to keep things clean and contact the best it can be.
    WilliamM2 wrote: »
    Once again you've taken the written word completely out of context and I never said he refuses to discuss it so it must be true. Here is what I was referring to. I'm sure you'll come back with some remark about him being in the industry so it fits his needs to promote.......blah,,,blah,,,blah.
    http://passlabs.com/pdf/old%20product%20manuals/x150_om.pdf
    See page 5 titled "Interconnects and speaker cables"
    P.s. Keep in mind he is speaking about "HIS" amplifier design not a blanket statement when it comes to IC recommendations
  • WilliamM2
    edited August 2008
    Out of context? Here is what you said:
    "A very well respected audio guru who won't debate the issue of cables with his components states he finds that the connection is just as important than the type of cable you use."
    Like I said, I don't see anything wrong with cleaning the connectors, it won't hurt anything. Read my first post.
    Personally, I disconnect my entire system about twice a year, and pull everything out of the rack to clean and remove dust. The very act of unplugging the connector, and plugging it back in would remove the small amount of contaminants.
    But this thread was about polishing the connector, not cleaning.
    edited August 2008
    WilliamM2 wrote: »
    He doesn't recommend any particular brand or design of cables because that's not his particular area of expertise. If you ask him directly he'll tell you what HE prefers in his system but he won't get into the "debate" about cables when discussing his audio products other than what he mentions in his owners manuals. It think it's a smart approach and he makes a good recommendation.
    WilliamM2 wrote: »
    Yes, I sort of thought polishing/cleaning connections was the same. But if the OP is saying to use some sort of exotic material and special cloth or machine to "polish" the ends then I agree, not nec. But cleaning the connections on regular basis 12-18 months certainly helps. I also pull my components out, inspect the cables, clean the ends and dust and clean. I also open up my amp and use compressed air to get all the "crap" out every 2-3 years.
  • JosephH1
    JosephH1 Posts: 17
    edited August 2008
    I think cleaning your connections is a good idea. This year I may go beyond just cleaning with alcohol and try the Caig faderlube, as it has a cleaner and a lubricant. I have some left over from a project receiver and will put it to good use.
  • ShinAce
    ShinAce Posts: 1,194
    edited August 2008
    As part of cleaning my connectors every once in a while, the rubbing action with a rag is enough to buff the surfaces a tiny bit.
    It's not like these connectors are wire wrapped together; they are not air tight.
  • blast8180
    blast8180 Posts: 11
    edited August 2008
    JosephH1 wrote: »
    Lubricant would not work so well. Liquids or oil based products tend to attract a fair amount of dust and airborne contaminants.
