Passive subwoofer crossover, free plus shipping
burdette
I have the passive crossover from a Crate PSM15S sub.
I think, not sure, but I think the crossover frequency was something like 200 or maybe 250Hz... but I don't know what driver impedence was used.
It has one BIG inductor, a smaller one, six or so large caps, a small circuit board, 1/4" phono plus two other inputs, 1/4" phono high frequency output. There is also a "defeat" switch. The whole thing is mounted on the back of a heavy piece of steel with mounting holes. I know it works - at least it does SOMETHING, because I had it hooked up to a different sub and I could definitely hear the difference when I turned it on and off.
I saved it because, well, it's a big-**** sub crossover, and I thought maybe I'd use it someday. Inductors and caps this big are expensive. But I know I'm not going to ever get to a project that would use this.
All I'm looking for is the cost of shipping... $10 or $15 I'd think.
Post edited by burdette on
That's a big transformer on the bottom. Looks like a pro-audio piece."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Its free...I'll....build something.
ChuckTesting
Testing
Testing -
stereo_luver wrote: »Its free...I'll....build something.
Chuck
Thanks. I'll be able to get back on here later tonight or tomorrow, and we can talk about arrangements.
Glad someone could use this.... -
Chuck
Chuck,
I sent this UPS on 8/2, and PMd you tracking information.. and have PMd you twice since then.
I don't know that you got this, and I've not received a check.
Update, please....
