Grrrr!!! Need help with Microsoft windows installer
danger boy
danger boy Posts: 15,722
edited August 2008 in The Clubhouse
This shouldn't be that tough, it really shouldn't.
In the old days.. you'd do a search for whatever it was you were looking for.. found the software and installed it. Done deal.
today I do a search for "windows installer" and it all links to third party software that you "install" for free, but to use it you have to pay for the dang thing. Plus it doesn't do squat either.
I could use some help because I am trying to update my old version of Ad Aware 2007. My computer won't uninstall Ad Aware 2007 and let me install Ad Aware 2008 because my computer's "installer" program is fubar.
Where can I go to download a free Windows XP installer program and not get linked to some software site? Or if anyone knows how to fix the installer program on my computer.. I'd much appreciate it.
thanks, AL
P.S. I'm also not sure I have XP SP3 or not. I don't remember if I downloaded that or not.
PolkFest 2012, who's going>?
Post edited by danger boy on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2008
    Al your SP3 question, Start, right click on My Computer down to properties, the general view should state XP service pack X.
    Now your Ad-Ware software can't you install over the old version if needed. But I would make sure all my Microsoft updates are done first.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • danger boy
    edited August 2008
    i'll try that Sal.
    Last night I tried 3 times to install XP SP3, but each time it failed on install.
    billbillw Posts: 7,548
    edited August 2008
    Sounds like your OS has a few parts corrupted. A clean install is probably the only way you will fix all your problems. Back up everything and start from scratch.
    Honestly, this should be performed every 2-3 years on most computers. Most people just suffer and end up getting new computers when they really only need a clean install.
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2008
    billbillw wrote: »
    I've had machines that I bought from a store (HP, Dell, etc.) that were so loaded with bloatware that I had to reformat and install a clean copy of the OS on them. I can't believe how much crap goes onto a modern PC when you first buy it.
    I don't do this every 2-3 years, I just do it when I first get the PC and then that's all.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • danger boy
    edited August 2008
    good idea on the clean install.. but I don't know if I want to do that.... the computer is due to be replaced the end of this year or next. I'm sure it would help though.
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2008
    billbillw wrote: »
    Careful, now you're going to get yelled at by people who claim this is never necessary, and in their 45 years of computer experience they've never had to format a drive.
    (I completely agree with you, btw, I've just been harassed for this opinion a bunch of times)
    edited August 2008
    bobman1235 wrote: »
    Well, I should have elaborated. I think it really depends how much installing/uninstalling the person does.
    My work computers, which never get anything installed other than Windows updates, work great after 3+ years. Prior to that, I had Win 98 computers at work that was mere than 6 years old and worked great with no reformatting.
    My home computer is a totally different story. All the software that I install and uninstall just ruins things after a few years.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited August 2008
    Format it, start from scratch. Sounds like a corrupt OS if windows installer is fubar and service packs aren't installing properly.....which means updates aren't installing properly as well. Format it....o, I said that already.
  • Serendipity
    edited August 2008
    I thought that I had to format my laptop too when I couldn't install anything
    (service packs, windows updates, Firefox, IE7, etc.)
    Turned out to be my Norton Antivirus.
  • BaggedLancer
    edited August 2008
    If windows installer is fubar....reinstall windows...you can try and possible succeed repairing it....but it's more hassle than it's worth. Move your data off and blow it away.
  • petrym
    petrym Posts: 1,912
    edited August 2008
    The Windows Installer CleanUp Utility is an advanced utility that'll take care of Windows Installer configurations. Be aware that it removes only the Windows Installer configuration information that is related to your target program; it does not clean the program out; caution is required. I've used this a few times and it works well -- you have to be sure of what you remove -- it's a no-going-back type of thing here!
  • Fireman32
    Fireman32 Posts: 4,845
    edited August 2008
    +1 on formatting and doing a clean install. I do this on my home computers every 2 years.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2008
    I am one of the 'reinstall once a year' guys. i create an image of my OS install with all the critical programs and settings that I use. Then every 6 months I restore that image and it's like having a fresh computer. Every 6 months is a bit excessive, but it works for me.
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    Just run a a chkdsk. Right click on your C drive go to properties.. then tools. Error check...It will tell you that it will scan the next time it reboots...make sure to check "aut fix errors" and "scan for attemp recover of bad setcors"
    Try this. It probably should be done anyways being the age.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2008
    bobman1235 wrote: »
    Well really, a complete re-install never is needed if you are smart. It's called a disc image, and there are several programs that work well. Just re-load the image for a nice clean install, takes all of 5 minutes, and you are back up and running.
  • dylan
    dylan Posts: 453
    edited August 2008
    Hi Al... you might try this link. Towards the bottom, download button for 'WindowsInstaller-KB893803-v2-x86.exe'.
    I don't think it will help in this case, but the installer cleanup utility is a great program for cleaning up other programs that have incorrect or corrupt entries registered with the installer service. For example, a certain program keeps asking you to insert a CD to continue or gets stuck in a loop uninstalling.
  • bobman1235
    edited August 2008
    Fair enough, I would still consider that a fresh install, just an expedited way of accomplishing it.
  • WilliamM2
    edited August 2008
    bobman1235 wrote: »
    Exactly, a fresh install, and without any effort.
  • AsSiMiLaTeD
    edited August 2008
    I highly recommend Acronis True Image for a disk image utility, though Vista now has a built in utility that should work okay I guess.
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    Are we doing all of this because Ad Ware and SP3 wont install?
    Try the chdsk first before imaging the intire OS.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • bobman1235
    edited August 2008
    His Windows installer is corrupted, this would affect any program that he tries to install (or uninstall) in the future. So yes, the problem presented itself with AdAware but will be a major PITA in the future if it's not fixed.
  • Serendipity
    edited August 2008
    Not trying to argue or anything, but when my laptop couldn't install SP2 or IE7 I seriously thought my Windows Installer was corrupted. It turns out most of my instability was due to Norton, I've since uninstalled it and have no problems whatsoever.
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    bobman1235 wrote: »
    Im just saying, I had a similar problem with an older system .. I ran the check disk ..it found many errors in the reg.. after fixing errors I was able to install again. My problem started when I tried to install AVG 8.0 over an older version.
    I also had a problem with permissions. For some onknown reason, my permission were all turned off. Bu **** seemed after running the check disjk, everything was ok.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    appadv wrote: »
    +1, many virus protectors get corrupted and stop any new installations of anything.
    Of corse I would never ever ever ever put Norton or McAfee on any system./
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited August 2008
    jakelm wrote: »
    That's exactly what happened. :)
  • WilliamM2
    edited August 2008
    jakelm wrote: »
    It would be a good idea to run SFC (system file checker) as well.
    edited August 2008
    WilliamM2 wrote: »
    This only works like you say if you make an image of a 'fresh install' right after you loaded up all your software. You still loose all of the data (email, photos, music, etc) that you've accumulated since you did the image, not to mention hours of windows updates, software patches, etc.
    Most of the time, you try to keep an image of your most recent good setup, say every month. The problem is after a few years, your 'good' setup gets worse and worse due to system clutter and you ultimately need a fresh install to clean things up.
    Obviously, you can save a lot of time if you keep multiple backups, one that is an image of just after a fresh install (assuming you haven't made any hardware changes) and one that is your most recent 'good setup'.
    Using Norton Ghost (that's what I use) you can pick out certain files from an image and restore them selectively. This can be a bit of work and you need to know what your doing (to restore email and such), but it can give you the best of both worlds. Restore your image of a fresh install, then restore email, photos, etc. You still would have to wait for windows updates and do whatever software updates, drivers, patches, etc. manually.
    Of course, all of this requires a fair amount of pre-planning.
    In Danger Boy's case, he's up $hits creek without a paddle and its probably only going to get worse. In my opinion, his only option for long term stability is to bite the bullet and reformat the drive and install everything fresh.
    Start finding ways to back up the critical data that you still have access to.
  • WilliamM2
    edited August 2008
    Right, and that's the way I do it. All e-mail and important files are backed up on another drive. Windows updates never take more than 15 minutes or so to get, if you have a decent connection.
    But you are right, it's too late for Dangerboy, but I thought perhaps he could use a better plan next time.
  • danger boy
    edited August 2008
    Lasareath wrote: »
    Danger,
    I just had the same exact problem with another client's PC, the windows installer is dead.
    This free program fixed it!!!!
    http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
    Sal
    Sal,
    thanks for the link.. it was easy to use.. and it solved my nagging installer problem. :D
    thanks man, AL
