db400's in a bike
demaples
demaples Posts: 266
edited August 2008 in Car Audio & Electronics
I'm considering replacing my 2000 Yamaha Royal Star Ventures speakers with 4 polk db400's. Anybody have any experince or input on this? Ths stock speakers sound ok but are weak on bass.
D
Hitachi 50" Plasma full HD 1080--Onkyo 805 AVR
Rotel RMB-1077 amp--Polk LSic center
Polk LSi25 fronts--Polk LSi 15 rears
Genesis G-2800 sides--Polk PSW 650 sub
APC H15 power conditioner--Netgear digital media player
Napster external hardrive--Linksys Wireless G router
Samsung DVD--Blue Jeans wires
Post edited by demaples on
  • exalted512
    exalted512 Posts: 10,734
    edited August 2008
    Either way, a 4" is still a 4" and shouldn't really be playing any bass anyway. The best thing to do is to take the fairing apart first to ensure there are no odd mounting brackets that might cause problems. While apart, also check any depth issues.
    Luckily, they're relatively straight forward. I want to put half of a Polk Audio DB5251 component set on my bike...unfortunately it'd have to be completely custom since I dont have speakers. But I'm not sure I want to shell out the $150 for a full component set...especially when all I need is half. I'm going to call Polk tomorrow and see how much it costs to buy it separate, unfortunately I think its going to be about the same as what I can get the full set online.
    -Cody
