2 Channel Sub Hookup?
wingnut4772
I am using (finally!) my Musical Fidelity A3cr pre but it does not have a sub out. How do I get some sub action in my 2 channel rig?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Thanks.:)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
http://www.radioshack.com/product/index.jsp?productId=2103638&cp=&sr=1&origkw=rca+Y&kw=rca+y&parentPage=search
BJC also carries something very similar."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
O.K. I am blonde. How would I hook that up?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Plug the male end into the sub.
One of the female ends will be coming from the amp/reciever. The other will go FROM the sub, to the front l/r speakers.
You would need 4 of these, and 4 sets of cables with that tip. Interconnects/rcas, whatever.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
You can install them on the "OUT" on your pre, one pair of cables to your 2 channel amp, one pair of cables to your sub(s). The cables would have to go to your in, not LFE, and you would adjust your crossover frequency, gain, phase, etc...on your sub instead of on your old pre/pro."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ok. My VR4 Jrs hit pretty low but I may try this out. Thanks guys.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
