OTL Amplifiers
zingo
zingo Posts: 11,258
edited August 2008 in Electronics
I just stumbled onto this idea of of OTL or output transformer-less tube amplifier. Does anyone have any experience with them? The claim is that since there is not output transformer, the signal from the output tubes is being sent straight to the speaker and that will produce a better sound quality. However, this will also give the amp less power, and thus more tubes required for the same output. For example, the single-ended, 1.5wpc amp uses 8 output tubes and the 15wpc stereo amp used 16 total tubes; and they claim low heat...
Transcendent Sound makes OTL amplifiers that look pretty interesting.
My choice off of the site would be the balanced input "The Beast" monoblock that outputs 160w at 8 Ohms that uses 16 EL509 tubes!
Post edited by zingo on
