Car help needed
ben62670
OK I am pretty good with mechanics, and I am pretty sure I know the answer. Well this morning I took my daughter to school, and her school is less than 2 miles away. I watch gages like I do the speedo. By the time I got to her school the temp gage was only reading 130. I was thinking how cool it is to live so close to the school. Well a nice quick drop off, and by the time I reached home the gage was in the red. Well Ash was sick tonight so I wanted to make sure that the car had plenty of coolant in it. So I fired it up, and after a little warm up time(cap off) the thing was popping out the radiator pretty good.
Ben
Ben
Post edited by ben62670 on
possible you blew a head gasket? what kind of car is it? any smoke from the tailpipe at all?
if not i'd say look at the thermostat for problems. i know on GM's you can get air in the system and the stat will not open. you just gotta squeeze the hose while it's running to work the air out.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Check your oil.
Does it look like a chocolate milkshake?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Yeah I was scared it may be the head gasket. It is a 96 Pontiac Grand Prix V6. The pipe had a little bit of water, but that could have been condensation. I think you may be onto something with the air pocket. It sounded like it was banging pretty hard, but air in a system can do that. I should pop out the thermostat, and test it. I have a compression tester, but the back plug are a nightmare to get out.
Ben -
Check your oil.
Did that check first thing;) Been there done that. No milk in the oil:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Is it a 3800? If there's air in the system, there should be a small valve on top of the thermostat housing. With the car cold, remove the cap and open the valve. Be careful not to turn it too many times, there aren't many threads and it's easy to lose. Start the car and let it warm up. If there is any air in the system, bubbles should come out of the small hole in the valve. Add coolant as necessary. Once you have a steady stream out of the bleed valve and the coolant level is good, close everything up and you're good to go."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Its a 3.1 AKA 3100Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Has the bleeder, but its pissing some seroius steam. I think the HG is gone:(Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben,
check to see if the water is flowing in the radiator
could be a stuck thermostat
Head gasket will have 2 signs:
1. smoke out the tailpipe like a freight train
B. Milky oil
b 1/2. Runs rough from missing cylinder where gasket is blown
Chuck
PS...check the thermostat to see if it is opening.....flowing water thru the radiator.
on that engine the water pump impeller can come loose and not pump water also.Testing
Testing
Testing -
Answer your phone!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You may have a blocked core in the radiator? NOT a monkey, but it happened to me.
Or, the impeller busted off the water pump?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Yes, check the flow. If it's flowing then check to make sure the electric fan is working. If no flow then check: If no water is leaking other than from the radiator then your possibilities are the thermostat or the water pump.
engtazengtaz
Can you smell the "sweet" aroma of coolant when outside the car? When my head gasket went I could smell coolant every time I stopped the car for about 3 weeks prior. When mine finally went it was steaming like crazy. Never did detect "milky" oil. Mine was a very small failure, but still a failure. As soon as it started steaming it was off to the mechanic. $1300 later like brand new. Not a Pontiac, FYI.
I'd check everything else before I'd go jumping to the conclusion it's a HG, unless that's a common weak point for your model car.
GL and glad to hear Ashley is doing better.
Make sure your upper AND lower radiator hoses are both getting hot.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
It doesn't sound good. If the temp gets that hot in just 2 miles, and there is no coolant missing, it's either a stuck thermostat or a head gasket. Usually the head gasket, because even with a stuck thermostat it shouldn't reach the boiling point in just 2 miles. Water pump impeller failures are pretty rare.
But of course, the first thing to replace is the thermostat and make sure those electric fans are running.
GM's are notorious for their intake gasket failures too.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Another possibility is the temperature sending unit is bad, but when it reads high, its best to eliminate the other possibilities first.
Most likely: bad thermostat or air in the system. I think a blown head gasket would give you other tell tale signs. -
I was trying hard to stay out of this one, but one of my last GM products ever stand...
I owned a 3.1 Chevy which had a cracked block. You need to due a pressure check on the radiator and do a compression check on the cylinders. Good Luck
Little or no cash? Major issues with a 12 year old car hmm.... Porter Seal
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Ah...just trade her in on a Kia.;):D"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Also check your radiator cap--they are an integral part of the cooling system now--seriously. I changed out a thermostat on a Neon years ago--turned out to be a bad cap.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
There is certain pressure(lb) rating for the radiator cap on your vehicle, they go bad over time as Steve has mentioned.
I think someone else mentioned it... What does the radiator fluid look like, is the radiator plugged up?? -
Radiator caps have a pressure rating and if you use the wrong pressure rating, it can cause overheating. The cooling system needs to build pressure to work right. The pressure the system builds up helps keep the water from boiling over and improves it's thermal efficiency.
If you are overheating that quick, either you have a cooling system problem like what was already mentioned with a bad cap or even something like a collapsed radiator hose. That can be caused by a stuck thermostat. It's usually the lower hose that collapses. Alot of cars have spring loaded hoses to prevent that but older cars that are as new as 1998 don't always have that. But a head gasket is a very real possibility but the 3.1's are notorious for eating intake gaskets too and they can cause pressure leaks.Expert Moron Extraordinaire
Thanks guys. I am taking a break from all this. I will hit it tomorrow;)
Ben
