Amp for lsi9
ctrulock
ctrulock Posts: 73
edited August 2008 in Speakers
Do you think a Mark Levinson 29 would be enough to power 1 pair of lsi9's? It is 100 watts into 4 ohms but is stable to 2 ohms?
Post edited by ctrulock on
  • Face
    Face Posts: 14,340
    edited August 2008
    Anything 2 ohm stable should work just fine.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2008
    I would hope anything with the Levinson name (and price) would do justice to the Lsi9s. . . regardless of if they met Cathy's 200wpc benchmark or not :)
    Go for it!
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
    heiney9 Posts: 25,447
    edited August 2008
    ctrulock wrote: »
    Ummmm......yes. Levinson is outstanding gear. When you are at that level of gear you have no worries.
    The Pass Labs Aleph30 is 30 wpc and I will have no problem running my SDA's with that.
  • Shannon W.
    Shannon W. Posts: 568
    edited August 2008
    Check out Carver Sunfire. I run my whole HT with a Cinema Grand Sig. 7 & its rated (on paper) at 800wpc @ 4ohms. Trust me it was the best money I have ever spent (well other then my SVS sub + Velodyne SMS-1 :) ) hehehehehe. If you just want a 2 channel amp check out their Sunfire Signature 600~two. its rated at 600wpc@ 8ohms, 1200wpc @ 4ohms and a time limited basis 4,000 wpc @1ohm rms per channel! Wooohooo. Plus the good thing is you can find these models on eBay and audiogon all the time for a good price. The good thing with sunfire is that even if that items warranty has ran out they will fix it no-matter what is wrong with it for only $450.00 Current Electronics (amplifiers, processors, receivers, preamps). I'm my mind, is cheap considering my amp new would have cost around $4500 and I got the deal of the day from a dealer that was no longer selling sunfire stuff for only $1900 with tax (and it was new).
    So there are deals out there you just have to look and be patient. I waited 6 years before I found the right deal and when I got that thing hooked up, My jaw hit the floor on how much more my LSi9's stood out.
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • meirco11
    meirco11 Posts: 47
    edited August 2008
    my polkaudio LSI9 sound very good,very very good indeed with my 100wpc ROTEL RA1070 integrated amp. the flagship rotel 10 series has a lot of power and clearaty. the lsi9 needs a powerfull amp.
    must to remember the breaking-in time(at least 160 hr.)of the lsi9.
    there is no question a bout the rule of the lsi9,superb speaker.
