RTA15 Repaired Successfully
gene stangel
gene stangel Posts: 35
edited December 2001 in Technical/Setup
Received and installed four 6503 drivers and RTA15 appears to be back to normal. Terminals on new drivers were opposite those on old drivers so I installed them with terminals pointing up so wires would not need to be twisted. Blue wire to positive. Please advise if this is not correct. Also my center channel system consists of a CS350 and a CS400 wired in parallel and powered by low impedance Maranz monoblock. Please advise if I am asking for trouble with this setup. Great sound in a big room.
Thanks, Ken for all your help and Polk for great service.
Post edited by gene stangel on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello Gene,
    I'm glad all's well with the RTA15s once again. Yes, the driver's terminal may be positioned in any convenient wiring arrangement (blue wire to positive terminal).
    It sounds as though the Marantz should not have any problems driving the parallel center channels, it should work fine to fill the room.
    Take care, Ken
