Got my TX-SR875 should I bridge or Bi-Amp
Dannieboiz
I only have a 5.1 setup and the 875 can either bridge or Bi-Amp, do you think is a better option for my RTi10?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Onkyo TX-SR875
Velodyne DPS-12
Post edited by Dannieboiz on
Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp, Bi-amp.....
Did I mention that it would be better to Bi-amp?
Bridging puts a lot of stress on most amps. I would also agree with Bi-Amp.
Ben -
you cannot bridge if the speaker's impedance goes below 8-ohms...
Dannie, a still better option might be neither of the above. The 875 is a quite powerful amplifier and lab tests have measured it at over 150 watts into 8 ohms. For most uses it has more than enough maximum power capacity in its standard form, and you shouldn't assume that it would be inadequate for you.
If the unlikely situation developed that a higher maximum power capacity was in fact needed, then your only effective option with the 875 would be bridging. The so-called "biamping" feature that the 875 and some other receivers advertise is a misnomer. Biamping requires two separate amplifiers(as the term implies)and a separate external crossover before the amplifiers so that they're only amplifying the required part of the frequency spectrum. A receiver has only one main power supply section and sending its voltage to a speaker through two sets of output transistors(one set previously unused for back surround speakers)rather than one can't double the available power, as some imagine, or increase it by any amount.
Bridging, on the other hand uses an entirely different process to send two voltages(but of opposite polarity)into the one set of speaker input terminals so that in effect while one voltage pushes, the other pulls the speaker driver in the same direction and they co-operate. Following Ohm's Law, power is proportional to the square of the voltage, so with perfect efficiency in the process the power output would theoretically be quadrupled when double the voltage was sent into the speaker by bridging. In practice, the power can be roughly tripled. Another effect is that although obviously bridging an amplifier can't change the internal impedance of a speaker, the doubling of voltage also doubles the current required(Ohm's Law again)at a given impedance.
So again, you're highly likely to have all you need right now, so relax and enjoy the great sound. -
Dannie,
I have a similar set-up and wondered the same thing. However, on page 24 of the pdf manual it says "When bridging is used, the AV receiver is able to drive 2 speakers in the main room (2.1 if you're using a powered subwoofer)." If you try bridging, please report whether you have a full 5.1 in operation.MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
John, thanks for the clarification.
First time I hooked up my system I did not have Audyssey setup so it was quite very load.
After I posted this question, I Bi-Amped the fronts then ran the Audyssey setup before I even tested the speakers again. Now Audyssey put a limit on my volume, it wouldn't go any loader than 28db.
I've only had the receiver for 2 days, I'll do more poking around next week.
I think I'm just going to do the standard hook up when I have some time. I never listen to 2.1 or stereo. I like my room sounding full, All channel stereo is the only thing I listen to when it comes to music.Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
