WTB: High end flat 21" CRT for gaming
neokeelo
Im looking for a nice 21 inch CRT monitor that still has good colors and black levels. I do alot of FPS gaming and LCD's just don't cut it for me.
I can't pay a lot but let me know what you got and how much shipping would be to 38362.
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
SUB - SVS PB12-NSD
Post edited by neokeelo on
You'll probably want something local. I think shipping alone on one of those is going to run you close to $100 because of the weight.
There are LCDs on the market nowadays that do gaming quite well - alot of people up to the guys who do professional reviews now use an LCD screen. I've got Gate and Dell 24" screens, and I do a good amount of gaming on the PC, and they're both great.
The one problem with LCD technology is that there isn't a panel out there which does it all well. Some panels are great for gaming because of their latency and overall good color reproduction, but those panels aren't quite good enough with colors to be suited for something like design work. There are other panels that have absolute stellar color reporduction that are great for design work, but that comes at the expense of latency and they're not well siuted for gaming.
I do both, so I have a couple TN panels for gaming and a S-IPS panel that I do all my graphics design and CGI work on. Don't get me wrong, the Gateway that I have also has excellent color accuracy, and should work for all gamers and about 99.9% of the rest of folks out there, but it's not quite good enough for design work. -
Newegg has a 21" crt.CRTs rule for gaming.Period. http://www.newegg.com/Product/Product.aspx?Item=N82E16824002090SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Check Amazon, I purchased a 21" CRT through them with free shipping."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
If you can fit a 24in go find a HP/Sony FW9012. When I bought it many sites recommended it and it was lauded as one of the best CRT Monitors ever made. .23mm dot pitch, 2304 x 1440 @ 80hz resolution, 22.5" viewable screen, etc. It is a professional monitor for graphic artists and such.
I bought mine for <$300. Never seen a better picture on any kind of monitor or TV ever. -
http://www.amazon.com/19IN-1920X1440-G90FB4-Black-Perfectflat/dp/B000EKC3VK/ref=sr_1_1?ie=UTF8&s=electronics&qid=1217700958&sr=1-1
19" Viewsonic with free shipping today only. It appears they don't stock my 21" Viewsonic anymore."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
This the only time I will recommend a dell product. Believe it or not the dell 21 inch lcd is the best monitor for gaming out there.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
