Converting DVDs to stream via Media Center
Shizelbs
What programs should I be using to convert my legally owned DVDs to a format that media center will play nice with. Retaining 5.1 audio would be ideal, but not necessary. One particular problem I'm having is finding a program that can, and knowing how to use it, that will extract episodes properly off TV series DVDs.
Post edited by Shizelbs on
There are quite a few programs and methods that can do this. I've done it before using a standard DVD ripper and set the program to demux the stream, which left me with avi files (which media player might be able to playback), but I wanted them to burn to a CD, so I found an AVI>WAV converter.
Try googling 'extracting audio DVD' -
Media Center does not do avi
Actually, I was thinking, AVI is combined video/audio.
Whatever program I used gave me other options that output straight audio files. They were either PCM, AC3, or some MPEG format.
BTW, Media Player will handle AVI with the right codec installed. I don't really know what you mean by Media Center (versus Media Player). Search for AVI+"media player" for answers on how to install an AVI codec.
Here is a good guide on audioextraction using all freeware:
http://www.carltonbale.com/project/dvd-audio-extraction/ -
Believe me, this is a complicated subject and I haven't found a single do-it-all program simply because there's so many variations (copy protection, audio versus video or both, chapters/episodes, codecs/formats, etc.). Having said that, I have been able to do just about anything I wanted, it just took some reading, experimenting, and usually multiple programs. There are entire websites devoted to audio/video extraction, conversions, trans coding/recoding, etc. If you want to explore further, try these. Drop me an email if you need more
Guides for how to do stuff
www.videohelp.com
www.doom9.org
A free program that will convert pretty much anything to anything but it is NOT an intuition program and has very little help available.
www.erightsoft.com/super.html
A pay-for program that will extract episodes from DVD's. It does require some expertise but there are instructions & guides on the website.
www.dvdfab.comSony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Thanks Marty. If nothing else, its just nice to know that what I want might not actually exist. I'll look into DVDfab and get my read on.
Right now my main problem is I don't have all day to sit around and see if my attempts are successful, then repeat over and over. -
It does exist. I've done it. It just takes some time fooling around with the various software(s). Give yourself a few hours on the weekend to read up at some of the sites Marty linked. I remember finding lots of good info at Doom9.
DVDShrink gets you chapters you select from DVD (and bypasses cope protection). DVDEncrypter takes the whole DVD. That's the starting point, after that you can do the conversion to mpeg or avi.
Alright, I am thinking that DVDFab should do the trick. Price is fair too. I'll just whole up in my office and play some vids while I wait for my rips and conversions.
I use the free version which does remove copy protection but does not do episodes so I can at least say it's a decent program. I can't speak to the ease of extracting episodes as I use the two Sami mentioned. They are no longer supported.
By the way, I think the DVDFab download is a 30 day free trial so you might use that time to experiment and make sure it does what you want before paying.Sony 60'' SXRD 1080p
I use NERO 8 Ultra. I can extract audio from DVD's and format to Mp3, AVI, WAV or whatever I want. I also use Anydvd to work around copywrite crap. For DVD's to "back-up" I shrink with Nero Recode.
For audio I use Nero Digital to extract the audio. Then I format to whatever I want for playback. This works for me and all I've used for years. But there are several other programs out there. Good Luck.
ChuckTesting
Testing
Testing -
I use DVDFab (free version), and after use TMPGEnc DVD Author3, It will edit them any way you want, so you can just grab episodes like you want, and can also convert them to avi.
I don't know why, but my version of Media Center plays AVI.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
clone dvd
I think its supposed to play them, but mine doesn't. I can play them just through the 360 guide under videos, but not through media center. -
You probably need to find the AVI codec and install it in the correct place. There are probably guides on the internet. -
Shizel, do a search for Combined Community Codec Pack. Nice all-in-one pack with every codec you could need, including DivX. That should get AVI files working in Media Center.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Or install the K-Lite codec pack. I have yet to find any video file that it does not have the codecs for.
Thanks for the tips on the codecs. I'll try that tonight.
I've succeeded at streaming videos and ripping DVDs, including breaking TV series down into individual episodes. Remaining problems are; not keeping 5.1 and the overall image quality certainly is not as good as it was on DVD. -
the matraska codec pack is great. Adds alot of compatability to WMC.
Also VLC will play just about anything besides HDDVD and Blueray. For that get power DVD Ultra.
I wanted to convert my DVD iso-images into a format that PS3 playes, and I came across a good encoder...Handbrake.
http://handbrake.fr/
