Opinions On Monster Power???
esrivkin
esrivkin Posts: 9
edited July 2008 in 2 Channel Audio
I am considering a Monster Power model MPA2250SS amp to push my RTi12's in the front.
Now I know it is not an exotic name like Adcom or Parasound or the others, but what I am wondering is, is it a high quality unit?
Blast away fellow Polk lovers....
Warm regards from too F*ckin HOT Vegas
What I got so far:
Mits 73833 DLP.............TV
Monster Power HTS 5100 MkII Power Thingy
RTi 12's........................Front (Black)
CSi5............................Center (Black)
RTi6............................Surround (Black)
FXi5............................Rear Surround (Black)
PSW 505..................... Sub (Black)
Undecided on receiver at present, leaning toward Denon 3808ci or Onkyo 875
As you can tell this is a work in progress, thankfully it is progressing FAST!!!
Post edited by esrivkin on
  • Systems
    Systems Posts: 14,872
    edited July 2008
    Is it hot enough for you? ( I hate that question. "Hell no, can we raise it another 30 degrees?")
    Never heard the Monster line of amps. Get one and let us know what its all about.
    Chuck
    BTW...welcome to the forums.
    Testing
    Testing
    Testing
  • ESavinon
    ESavinon Posts: 3,067
    edited July 2008
    I've heard good things about those amps.
    Highly praised but,i've never auditioned them.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dave shepard
    dave shepard Posts: 1,334
    edited July 2008
    If you do a search on this forum their was a Polkie (can't remember who) that did a side by side and the Monster did really good according to his wright-up.
    Dave
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2008
    I heard one and thought it was icky, too harsh and grainy for me, if you really like your treble hot then it may fit what you need. ScottVamp who used to hang here loved the things, so it always a subjective thing, btw I think they cost more or the same as the Parasound or NAD or Adcom.
    My favs are are the B&K, NAD, and Parasound.
    RT1
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    I have an Adcom GFA-555 that has been modded up for sale here. Plenty cheap enough that would push those with no problem.
    Ben
    Ben
  • unc2701
    unc2701 Posts: 3,587
    edited July 2008
    If I recall correctly, those are just a re-badged Marsh power amp. They were a pricey at MSRP, but could be had cheap on the used market.
    Backburner:Krell KAV-300i
    heiney9 Posts: 25,492
    edited July 2008
    unc2701 wrote: »
    Not rebadged in any way shape or form. They were Richard Marsh designs(or based on his designs) but a far cry from the Marsh line of amps.
    EDIT: I'll add that because the March line of amps are better doesn't mean the Monster amps aren't any good. When they first came out they were, IMO, horribly overpriced but on the used market you do get a decent amp for not a lot of money. I think it would be best suited in an HT environment. As RT says they are a bit "hot" up top so they may not play well with your RTi's but give em a try to see. You could do a lot worse.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    I have heard good things about Monster Amps give em a whirl. See if you like them.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    You should buy bens adcom 555. A real bargain and its modded so its better than stock.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • dmaic
    dmaic Posts: 8
    edited July 2008
    Monster has a solid rep and a good product. Compare the specs and dont let a name fool you into thinking that it can produce better sound because of the brand.
  • maxz28
    maxz28 Posts: 19
    edited July 2008
    I've heard good things about Monster, but never auditioned one myself.
    POLK SDA-1 SIGNATURE SERIES
    POLK RTA-12
    POLK 7C
  • ben62670
    edited July 2008
    Boycott Monster:mad:
    Ben
  • higgins79
    higgins79 Posts: 72
    edited July 2008
    I can say that I love mine, however I haven't really compaired it to much else except some outlaw monoblocks (which i also liked) It weighs a ton puts out alot of juice and isnt to bad if you can find one below msrp.
    TV ................Sony kdl52xbr4
    Reciever ........Denon AVR 988
    Amp -............Monster MPA 2250
    Bluray............Sony PS3 (80gig)
    Hddvd............xbox 360 Hddvd
    Power centers.Monster 3600II & 2600II & 1600 x2
    Voltage..........Monster AVS 2000
    Fronts ...........polk Rti12s
    Center ..........polk Csi5
    Rears.............polk Fxi5s
    Sub ..............Infinity PS12
    cables............Monster / DIY
    Video games...XBOX 360 / Wii
  • dkg999
    dkg999 Posts: 5,647
    edited July 2008
    IIRC, the, or some of, Monster amps were Marsh designs that were built for Monster by Rockford Fosgate, utilizing components and parts specified by Monster. So the circuit design may be Marsh, but if you believe things like the quality of the wire, caps, resistors, connectors, etc. make a difference, then the sound signature would not be the same.
    That said, at the last IL Polkfest I believe that Mike was using Monster amps to power his LSi HT, and it sounded pretty good. Or maybe it just felt pretty good? It was hard to distinguish between sound and vibration at some points :eek:
    DKG999
