Cleaning your gear
Early B.
What's a good cleaning agent for my gear that won't fade, smear, or remove the lettering?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Purified water with a very gentle buffing cloth. You could mix in some non-ammonia windex at a 25/75 H2)/Windex blend.
I tried to pump Doro for his advice, but he would not give up his secret. I heard goo gone is supposed to be good.
Ben -
I use a microfibre cloth and turtle wax. Apply gently and you shouldn't have a problem. I use this method on some of my McIntosh gear from the 60's and the silk screening is still intact."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Chamois and warm water. Ask anyone who has bought gear from me--plastic display faces look brand new. I also use a chamois on my rear projection DLP screen, and dusty speaker cones. Works great for CD/DVD disc cleaning too. Just make sure it's a real chamois--not some synthetic crap. Local auto parts store has them.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
For all electronic parts including pots & INSIDE RCA connectors, use Caig DeOxit Gold. Don't get the cheezy spray; use a q-tip with the liquid. one of the best things you can do for an old piece.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Laquer thinner or acetone works really well. Ok I'm kidding.THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
I use "Invisible Glass". A Stoner product. Makes my gear and glass shelves look like they just left the factory.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Endust makes an electronics cleaner that works great. Anti-static cleaning and dusting spray. It used to be in a blue can where you buy regular Endust. I've used it for a couple years now and it works great. Gets rid of smudges and cleans things up real nice, including glass display windows and TV screens (CRT anyways).
Highly recommended.
Just a damp clothe works well for me. Some things it doesn't clean up 100%, but its worth it to me knowing that I'm not **** anything up.
I've been using Windex, sprayed lightly on a soft cotton cloth, then wiped lightly on the gear, for years and years. I've never had any problems. YMMVPolitical Correctness'.........defined
President of Club Polk -
Windex is good stuph w/lots of uses...I've been using it on cuts and bruises ever since I can remember. :rolleyes:
But Windex has Ammonia in it. Not good for the lettering etc. The Endust Electronics cleaner works the best of anything I've tried, except for extremely stubborn stains. It's oil, ammonia and wax free as well as static free."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
+1... -
LOL @ the Greek Wedding reference.Windex is good stuph w/lots of uses...I've been using it on cuts and bruises ever since I can remember. :rolleyes:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I've heard that before and wanting to be sure, so I tested the use of Windex on an old Pioneer's faceplate. I sprayed the Windex directly on the faceplate and rubbed really hard, repeating the process over and over. In the end, the lettering looked as good as before the test. Now, that's not to say it wouldn't affect some other piece of gear, so it's always best to test any cleaning product before using.
BTW, the Pioneer is in some landfill now.
I use windex on my gloss finished products (Lsi's, meridian, anything shiny). For other stuff, usually just warm water and a soft / microfiber cloth. I'll used deoxit on old stuff that comes in beat up or real dirty.
A lot of times I'll just wipe it off with a pledge dry dust-cloth. Those things are great for everyday use with audio gear and/or anything else.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Are you sure it's not the one Danger Boy has been battling with?BTW, the Pioneer is in some landfill now.
I used Windex today on my preamp. Works great.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
The blue stuff does. They make some "ammonia free" Windex but if you look at the ingredients it has .18 lactic-acid, whatever the hell that is. I vote for the Endust although that product for "stoners" sounds interesting.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Anyone uses laquer thinner or acetone will learn a good lesson for life. I am not kidding.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
I just used distilled water and microfiber cloth.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
I use Windex, the blue stuff. I have a couple of components that are twenty years old, and have been using Windex on them the whole time. They still have all the lettering intact, and look as good as the day I bought them. The ammonia is not going to harm anything, especially if you wipe it on, and wipe it right off.
I am telling you guys. The ENDUST product for cleaning electronics works about the best out there and it's 100% safe. Ditch the Windex and get this stuff.
It comes in baby wipe packaging
OR
In a spray can
If "pledge dry dust-cloth" contains pledge - Keep it away from wood.- the stuff prevents refinishing. (you'd need to strip down to bare wood - and scrubb the bejezes out of it.LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
I use that as well but if I want things to shine I use meguiers NXT tech protect. It's like armorall BUT its not gressy like it and does not atract dust as well. I also use it in my car
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
hehe
Hey, it really does work great on cuts and bruises though. Try it the next time you get a headache.
Apply directly to the forehead? Apply directly to the forehead? Apply directly to the forehead?
:D:D:D:D:D;) "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
OR
In a spray can
I'm listening:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
