XRT12 antenna conversion
bigyank
I am in need of adding antenna cable to go outside. My rig's current location disallows antenna aiming toward the south/southwest as the manual states due to trees being in the way.
My concern is I have an RG-6 (50 ft) run available to me but the antenna connector with the XRT12 is not an F-type connector.
Any thoughts? I do not want to run another cable through the wall (RG-6 is already) so the 50 ft extension cable is out.
Yank
Yank
Polk Monitor 7
Polk Atrium 55
Polk Atrium 55
Post edited by bigyank on
http://www.rfconnector.com/connector_quick_search.php?id=5
These guys have F plug adapters.
You also might be interested in the Terk XM6 Antenna. Its an exterior antenna
Hope that helps
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Started poking a little more after I opened this thread. It seems that the Terk XM6 has the required adaptor. I might get the signal booster as well and add another 50' run to get the antenna to a much better site.
Thanks for the reply!
YankPolk Monitor 7
Polk Atrium 55
