Was I Hacked?
jakelm
jakelm Posts: 4,081
edited July 2008 in The Clubhouse
Late last night, catching up on Polkies, my Linksys messege window popped up saying that "unnamed device connected".
I checked the device in the statis window. Turned out to be an unnamed wireless connection. It named itself Allison. It did not show wether it was a PC or Xbox or anything of the sort.
Now this is very wierd because my closest neighbor is about 70 yards from me and the road is even farther down my driveway. How can this happen?
I immediately went and changed my WPA security on the router for wireless connection. After than the "Allison" seemed to disconnect. Or maybe just showed as disconnect.
Was my wireless connection hacked?
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • bobman1235
    bobman1235 Posts: 10,822
    edited July 2008
    Maybe your house is haunted by a techno-ghost.
  • dkg999
    dkg999 Posts: 5,647
    edited July 2008
    Most likely yes! My IL residence is an apartment and I had to put security on my wireless or I had several neighbors trying to use it. My Linksys wireless router at my farm in IA will let me connect with my laptop from my one building which is about 400 yards away.
    DKG999
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    It probably was someone out on the road trying to see if they can get free internet. I do it sometimes. If you have a wep key you are fine unless you are sharing files with other computers on your network your fine.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • bobman1235
    edited July 2008
    So did you have WPA on, and just changed the password?
    WPA is nearly impossible to hack, so I'd be really surprised if someone made it through that. If you were unprotected or just had WEP on (there are free programs on the internet that can hack a WEP key in about 6 seconds), then most likely yes.
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2008
    Yep--someone was "sharing" your connection. Pedophiles like to do this to remain anonymous--lock your security settings DOWN.
  • PhantomOG
    PhantomOG Posts: 2,409
    edited July 2008
    might as well enable MAC filtering for your devices as well.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    bobman1235 wrote: »
    No when I checked it was not on at the start, but at seen as I enabled it, the connection seemed to been lost.
    I didnt think a connection could be made from that far away. Thats a strong wireless router.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    steveinaz wrote: »
    How do you lock them down?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    PhantomOG wrote: »
    I didnt see anything about MAC filtering. I dont want to mess up any of my wired connection with my other PC's or 360
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    WPA gave me an option to refresh it? Or re issue a small 4 letter key. I really dont know what it was doing, but I picked the highest security setting.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    edited July 2008
    Give it a security key, enable 128bit encryption, and then go into your "allow" menu and only allow MAC addy's that you specifiy. I have a Toshiba PC 5000 (I think???) so I don't know if the above applies fully to your setup...
  • PhantomOG
    edited July 2008
    MAC filtering info
    if you look up documentation on your specific router, there should be steps to enable it. Then you just need to find the MAC addresses for all your wireless devices.
  • bigaudiofanatic
    edited July 2008
    Just us what you are using you will be fine as long as your WPA is on and your MAC filtering is on.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bobman1235
    edited July 2008
    jakelm wrote: »
    Wired connections shouldn't be affected by any of these changes - I'm pretty sure evne MAC filtering only applies to wireless connections.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    Thanks.
    I think WPA highest setting, does enable MAC filtering. Or there was something about it. Now that I think about it.
    I was pretty freaky. But I loved the fact that Linksys messenger notified me of the connection.
    The funny thing is, I went straight to network settings to view the PC's on the network, and nothing showed up the the PC I was using
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PhantomOG
    edited July 2008
    jakelm wrote: »
    If you enabled MAC filtering you would definitely know it because you have to manual enter in the MAC address for each and every wireless device you want to allow. Do you even have wireless devices?
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    PhantomOG wrote: »
    Thanks ecactly what it told me I needed to do, but since I have no wireless connections I clicked finished.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PhantomOG
    edited July 2008
    If you have no wireless devices you should just disable the wireless connection on your router. If and when you do get a wireless device, then enable and worry about the security settings then.
    People can't hack your wireless connection if you don't have one to hack.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2008
    Wait couldn't that connection be another computer trying to connect to another computer for fun? Not another computer connection to his network, because I don't think he would see another device connected message.
    A say fun when I started this wireless stuff it was fun to see what you could do, a little fun got really old really fast. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • steveinaz
    edited July 2008
    PhantomOG wrote: »
    Exactly, simply disable wireless connections.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    disneyjoe7 wrote: »
    But it would have shown up in either, the Linksys devises or computers on my network? It only showed as an unknown-unnamed devise in the Linksys window and nothing in the microsoft network.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • dkg999
    dkg999 Posts: 5,647
    edited July 2008
    Maybe Allison is a hottie and you want to connect with her :D Did you check to see if there is a setting for that :rolleyes:
    DKG999
  • PhantomOG
    edited July 2008
    Seriously... you should disable the wireless connection on the router. There's no sense in opening yourself up to even the smallest chance if you have no wireless devices. It just doesn't make sense to leave it turned on.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    PhantomOG wrote: »
    Your right.
    When I set it up, I went the quickest easiest route. I think I'm pretty ok now.
    This might be a dumb question, but BlueTooth cant log on to a wireless connection, can it?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    dkg999 wrote: »
    Dont worry, if Allison would have shown up on my network, I would have tried to hack into her/it.
    SHe did, however, show to have a brief IP address. I noticed it right before I re/did my security settings..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Jstas
    Jstas Posts: 14,978
    edited July 2008
    Wish I had seen this sooner. Seems like all the help got you to where you need to be.
    As for war driving, I will tell you that even if your driveway is 100 yards long, I have wireless cards in my possession that can be parked 500 yards away and still drag in the faintest signals. Lock your stuff down. Use WPA security, it is very difficult to break. Use MAC address filters. Keep your security tight. I can't count the number of times I have sat in a bar somewhere or just pulled up in a parking lot of an apartment complex, started up the laptop with one of those bad **** wireless cards in it and just scanned looking for open access points. It's scary.
    And before anybody gets any ideas about any illegal activities I might have participated in, a friend and I used to do this to make extra money in school. We'd go war driving, find open access points, break in and leave messages on people's screens saying they had been compromised and then leave a phone number and message to call us for a free consultation. Between $20 and $50 a shot depending on the number of systems they had. We'd go war driving on a Tuesday and have the weekend booked up with appointments by Thursday night. Between the two of us we could pull in a cool $1500 in cash some weekends.
    Expert Moron Extraordinaire
  • phuz
    phuz Posts: 2,372
    edited July 2008
    Don't broadcast your SSID either.
    You could have the weakest most puny wireless AP/router in the world, and someone miles away could pick it up with the right antenna.
  • mutelight
    mutelight Posts: 1,054
    edited July 2008
    Jstas wrote: »
    But that is illegal and you left self incriminating evidence. :confused:
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • Jstas
    Jstas Posts: 14,978
    edited July 2008
    mutelight wrote: »
    10 years ago you could get away with it.
  • bigaudiofanatic
    edited July 2008
    Company's actually hire people that have hacked there system to show them what was the weakest port and so forth. In NY people sit outside and try to hack the business system after they have the go on in and explain what they did. Make quite a bit of money.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
