Advantages of Bi-wiring
dei08dei
dei08dei Posts: 29
I am sooooooo new to this. I just heard of bi-wiring. I have a CSi5 center channel, RtiA3 front surrounds and RtiA1 surrounds (4ea) in a 7.1 setup. My receiver is a Yamaha RX-1400. Is bi-wiring even worth the time with my setup? What are the advantages...is any? Which speakers would I do? Just the fronts? As you call all tell, I have much to learn. (I am replacing Bose speakers....FINALLY).
Thanks to all!:confused:
Post edited by dei08dei on
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    I don't think it is worth it, but if you have the extra speaker wire laying around - why not give it try and see for yourself?
    On the amp end - hook 2 sets of wires up to the right channel and 2 sets of wires up to the left channel.
    On the speaker end, remove the brass jumper between the red posts (and the jumper between the black posts) and hook one set of wires going to right speaker to the top black and red posts on the speaker and the other set of wires going to the right speaker to the bottom black and red posts on the speaker.
    Repeat for the left speaker and report back with your findings.
    Michael
    treitz3 Posts: 20,019
    edited July 2008
    Bi-wiring or Bi-amping? You said Bi-wiring, but I would just like to make sure.
  • dei08dei
    dei08dei Posts: 29
    edited July 2008
    treitz3 wrote: »
    Bi-wiring. Thanks.
  • dei08dei
    dei08dei Posts: 29
    edited July 2008
    McLoki wrote: »
    Michael
    The only thing I am not sure of is if I can get two wires in my receiver posts.
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    If not, you could always use one set of bare wires and one set of bananna plugs...
  • dei08dei
    dei08dei Posts: 29
    edited July 2008
    McLoki wrote: »
    Thanks. I will work in it.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    First welcome to club Polk. Second I used to be shy about bi-wire. I still think if budget is low then get a nice set of AQ type4. I run type4 for the lows, and I build Silver wires for Polkies that work especially nice on the highs.
    Ben
    http://www.polkaudio.com/forums/showthread.php?t=69977
    Ben
