Turntable advice
    billbillw Posts: 7,739
    edited July 2008
    ben62670 wrote: »
    17*17
    Thanks Chuck
    Might want him to make it bigger for when you upgrade to a VPI in about a 6-12 months ;)
    Since early 2006, I've been through 2 Technics, 1 Yamaha, 1 Oracle, and finally my VPI, which is going nowhere. I also have a spare Technics SL1300 laying around too. Vinyl is addictive!
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Well I just picked up the 200gram DSOTM album today. I am getting ready to spin it. What is the 1300 like? Any good?
    Ben
    Ben
    edited July 2008
    ben62670 wrote: »
    Ben
    Its supposed to be pretty good, but I've never actually played any vinyl on it.
  • ben62670
    edited July 2008
    I'll test it for ya;)
    Ben
    edited July 2008
    ben62670 wrote: »
    It doesn't have a cartridge at the moment, which is why I haven't used it.
  • ben62670
    edited July 2008
    Pmount or 1/2"?
    Ben
    edited July 2008
    ben62670 wrote: »
    Pmount or 1/2"?
    1/2". I've been looking for a decent cheap cart, but then decided to just hold off and get an M97xe. Just haven't pulled the trigger yet.
  • ben62670
    edited July 2008
    That looks like a pretty cool table. The direct drive is not a sought after thing, but the way they implamented it is good. I wish I had a cartridge we could play with.
    Time for me to spin some more vinyl.
    Ben
    Ben
    SCompRacer Posts: 9,121
    edited July 2008
  • ben62670
    edited July 2008
    Yes Rich I just may do that;)
    Ben
    Ben
  • mak99
    mak99 Posts: 362
    edited July 2008
    Ben give me some measurements on the size of your TT base. I am making several isolation decks from granite and marble out here on the west coast while I have the chance to get the material. You'll just need to supply some isolation feet under the decks. It looks like 18"x14" is the average but check your's anyway.
    Chuck
    Chuck - tried to reply to your PM about these slabs, but your mailbox is full. Feel free to contact me directly at kma_av at yahoo.com.
    Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
  • Audio NUT
    Audio NUT Posts: 63
    edited December 2008
    QUESTION: HELP I bought a dead mint JVC turntable vintage very nice BUT its from the CD4 quad system ( the receiver and records are all 4 channel quad as is the turntables cartridge) I put on a SHURE vr15 stereo cartridge and when playing a regular record im missing alot of the music ( very faint but definitly not right) the wires on BOTH the stereo and 4 channel cartridge both only have 4 wires red blue white and green and BOTH in the same set up ( where the wires attach to the cartridge and the head. The wires on my technics are Green/ Red going to the one side RCA and the blue/white going to the other RCA . there were two BLACK wires coming out of the arm housing and I disconnected them ( they were attached to some of the colored wires where the RCA wires meet them) with the black wires attached and taken off its the same still Much of the music is missing. Is there anyone with set up info for this, Im guessing the signal from the cartridge is proper as its the same as the regular shure BUT I may have missed a step.. any help.
    Could it be the ONE of the wires (red blue green white) is not connected. I guess I can check, but would ONE of them case this? thanks
  • hearingimpared
    hearingimpared Posts: 21,136
    IIRC you have to play a four channel record using a four channel cartridge. The Shure V15 is a two channel cartridge. Look at it this way. Try playing a mono record with a stereo cartridge. It still produces mono.
  • mmadden28
    mmadden28 Posts: 4,283
    Wow, they made 4 channel Vinyl? Phew-I'm def outta the loop there.
    ____________________
    Pool: Atrium 60's/45's
    The quad cartridges just had extended high frequency response. They were not really a 4 channel cartridge. The CD4 rear channel tracks were just encoded into the stereo mix with a high frequency carrier, which ends up being decoded by the quad receiver.
    Check continuity between each of the leads and the RCA outputs. The black wires are probably grounds for the tonearm. If you have any ground loops hum, they might help to eliminate it.
    Are you sure the V15 is in good working order? If everything is working, you would at least get good quality front stereo out of the V15. It might not pick up there rear channels if the frequency response is not good enough on the high end.
  • hearingimpared
    Thanks for the clarification Bill.:)
