RX797 and SDA-1Cs
CivilianJames
CivilianJames Posts: 1
edited July 2008 in Vintage Speakers
I have an old set of of SDA-1Cs. Can I run them with an Yamaha RX797 receiver or is that underpowered for those speakers?
Post edited by CivilianJames on
  • george daniel
    george daniel Posts: 12,096
    edited July 2008
    Yep,, careful with that volume though,, as you don't want to "clip" the amp.If you plan on keeping/using them,, a higher current/power amp would be in order. Good luck and have fun.
  • Marty913
    Marty913 Posts: 760
    edited July 2008
    Shouldn't be any problem. The 797 spec sheet mentions "4 Ohm rated" X 100 per channel. I drove mine for a while with a 75 watt HK although at admittedly lower-type music volumes but some of the movies got pretty loud. It should be just fine unless you play it for the neighbors. :rolleyes:
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
    heiney9 Posts: 25,408
    edited July 2008
    The 1C's present a demanding load and while the receiver will produce sound it's not the best long term solution unless you want background music. A separate amp is the best solution but you can "get by" with a receiver at low levels for awhile.
    Also FYI, I have 1C's so I am speaking from experience not a spec sheet. :)
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2008
    heiney9 wrote: »
    +1...same deal
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dbnh
    dbnh Posts: 194
    edited July 2008
    Keiko wrote: »
    I'm with george, heiney and Ron. I have the same receiver. It is a 2 channel workhorse, but for those power hungry speakers, you're better off with an amp.
    I agree with the separate amp camp. I have Odyssey mono extreme amps (need to make sure you use the correct Polk IC iteration when running monos), and find the Polks breath so much easier and with great finesse when powered this way. Good luck with your decision making.
  • dcmeigs
    dcmeigs Posts: 708
    edited July 2008
    You should try to get ahold of a 200 wpc amp for a day (beg, borrow, audition) and listen to the improvement that a good amp makes. The larger soundstage and tighter faster bass more than justifies the expense.
    The world is full of answers, some are right and some are wrong. - Neil Young
