Box install in trunk on 03 civic 4 door
eloplayspoloeloplayspolo Posts: 1,117
edited June 2008 in Car Subwoofer Talk
I dont wana make holes in my trunk, whats the other options? i was thinking lots of velcro or a bungie?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • MacLeodMacLeod Posts: 14,365
    edited June 2007
    You shouldnt have to cut holes in your trunk. Get you an L bracker or two depending on how big and heavy the box is and screw it into the trunk liner.
  • neomagus00neomagus00 Posts: 3,909
    edited June 2007
    hmm... depends on the weight of the box... the first time i l-bracketed my box, it tore out six screws from the liner and eight from the wood under the floor (and then slid across the trunk, pulling out the amp and the battery, too - uphill corners give you a lot of traction)... consider using more than one bracket :)
  • strang22strang22 Posts: 32
    edited March 2008
    I would recommend ell brackets
  • black magicblack magic Posts: 799
    edited June 2008
    You can also use a thin board of mdf as the floor of your trunk. Just throw it under your carpet to replace the stock board and use "L" brackets to screw your box to it.
  • eloplayspoloeloplayspolo Posts: 1,117
    edited June 2008
    lol this post is OLD.
    2013 Toyota Prius
    Mosconi 6to8 v8
    edited June 2008
Howdy, Stranger!
