Box install in trunk on 03 civic 4 door
eloplayspolo
I dont wana make holes in my trunk, whats the other options? i was thinking lots of velcro or a bungie?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
You shouldnt have to cut holes in your trunk. Get you an L bracker or two depending on how big and heavy the box is and screw it into the trunk liner.polkaudio sound quality competitor since 2005
hmm... depends on the weight of the box... the first time i l-bracketed my box, it tore out six screws from the liner and eight from the wood under the floor (and then slid across the trunk, pulling out the amp and the battery, too - uphill corners give you a lot of traction)... consider using more than one bracket
I would recommend ell brackets
You can also use a thin board of mdf as the floor of your trunk. Just throw it under your carpet to replace the stock board and use "L" brackets to screw your box to it.
lol this post is OLD.2013 Toyota Prius
Mosconi 6to8 v8 -
eloplayspolo wrote: »lol this post is OLD.
pshh. 1 year isnt old!
