Need Center Channel and Surround recommendation, Please!
I've just entered the realm of hi def tv and have hooked up my existing Polk RT800i's and PSW350 sub. I need a center channel and surrounds. Does anyone have a suggestion? The suggestions I've found on Polk's website have all been for discontinued speakers....
Post edited by ERM on
That's what you need. Speakers from the RTxxxi or RTxxx series. In short, you need to match the trilam tweeters.
thanks for the response, so am I correct in saying then that Polk no longer produces a center speaker that is compatible with my RT880i's?
No they don't. You can find them used, though. Check to see all of the models that would work and look for them.
