140 VOLTS fed to speaker
joeparaski
That's what my tech guy measured on the amp the destroyed my 3.2 tl recently.
The upstairs system is up and running thanks to some club Polk members. The amp will be repaired and returned to service.
Damage was done only to the right side speaker. The crossover survived and and left side SDA speaker is ok.
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
I'd recommend holding the line voltage going to your speakers to 110v ... maybe 115, but no more.
:eek:
Ouch !
Which amp did you have driving the 3.1 tl ?Sal Palooza -
mrbigbluelight wrote: »I'd recommend holding the line voltage going to your speakers to 110v ... maybe 115, but no more.
:eek:
Ouch !
An older Bose 1800, it's rated at 250 wpm at 8 ohm. I guess it was tired.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Oh wow. I s'pose that'll do it!
But, need I even say it? What'd you exPECT with that amp?!?!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Hmmm I wonder how this is possible. 140V going into the amp or out of the amp?
140V going into the amp = 140/8 17 amps into the speaker. Or 2400 watts.Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340 -
I bet it sounded badass while it worked.
The amp should be ready this evening. My tech guy found a service bulletin referring to this type of failure and the fix to prevent it. I'll get it done to my other 2 Bose 1801 amps.
He also serviced my SAE 2500 amp that was cutting out. Adding new binding posts, rca connectors and upgraded power cord.
