Wii Sensor Bar
Serendipity
Hi,
I'd like to extend the sensor bar cable on my Wii so that it reaches from the equipment rack to the top of a projection screen. I'm planning on splicing the wire and extending it with basic 24ga. wire.
Has anyone done this before and does it work at LONG distances?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Nyko or someone makes a wireless version.
Sure, the wireless sensor bars are a great idea, but will extending the Nintendo sensor bar wire work?polkaudio RT35 Bookshelves
